Re: Using Encoders with Labview and Mecanum wheels
Step one: Make sure you don't have any mechanical issues. Any extra friction on the motor/gearbox/axle/wheel system will mess you up, and unbalanced weight distribution can also lead to difficulties in controlling things.
Step two: Make sure your code knows what kind of speed controllers you are using. Victors and Jaguars have somewhat different default response to the PWM signal. The WPI Library motor control functions know about this and take it into account. Step three: If you are still having problems, ask again (and mention closed-loop speed control). |
1. everything is great mechanically, right now it's just a frame wheels and electronics,
2.we re using jaguars, it's in the programming. what would the term be for what i am looking for? i want all wheels operating at the same speed, prefferibly without close looped anything, becasue of the rule change this year we are getting readings from the encoders how do we tell the jags to stay at a constant speed? |
