Go to Post Come on, guys, it's two weeks 'til build. Personally, I'm gonna go outside for a little before I forget what my neighborhood looks like in the daylight. :) - Libby K [more]
Unread 24-01-2011, 11:43
jackdawg's Avatar
jackdawg jackdawg is offline
AKA: Wyatt Cerilli
FRC #1307
jackdawg is an unknown quantity at this point
no comms with c-rio on delpoy
we have done the updates to the driver station and set our network up to spec. we have also formatted the CRIO with the 2011 imaging tool and image.
however when we go to use the same connection (ethernet) to deploy code we get a comms error right at the start. everything seems to be in order. the Crio is not in safe mode and everything looks good.
anything i might have missed??
if anyone else has the same problem or a fix it would be great
thanks
-FIRST Team 1307 lead programmer.
Unread 24-01-2011, 11:51
Re: no comms with c-rio on delpoy
What programming language/environment are you using?
Have you told it what your team number is so it can try to talk to the cRIO using the right IP address?
Unread 24-01-2011, 11:59
jackdawg's Avatar
AKA: Wyatt Cerilli
FRC #1307
labview and yes with the image i did tell it the team number.
unless there is somwhere else to tell it the team number that i am unaware of.
Unread 24-01-2011, 12:07
arizonafoxx's Avatar
arizonafoxx arizonafoxx is offline
FRC #4395 (T-Rex)
arizonafoxx is an unknown quantity at this point
Are you using a crossover cable or straight through?
I know when we went to reimage the cRio this weekend we tried a straight through cable and it would not communicate with the cRio, but once we found the proper cross over cable, the cRio was instantly recognized by the imaging tool on our laptop.
Unread 24-01-2011, 12:10
jackdawg's Avatar
AKA: Wyatt Cerilli
FRC #1307
i am fairly sure it is a straight cable. not crossover but we did have success imaging with the current cable.
Unread 24-01-2011, 13:02
mike1010100 mike1010100 is offline
FRC #1307 (RoboSaints)
mike1010100 is an unknown quantity at this point
(I am on the same team as jackdawg^^^^^^^^^^^^^^^)
we have tried a PLETHORA of cables, upwards of 15, so we have reasoned out that it is most likely not one of the cables.
Unread 24-01-2011, 13:09
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
are you hooking to port 1?
Unread 24-01-2011, 13:15
I am pretty sure that we tried that, though the d-link is currently in that port ATM
Unread 24-01-2011, 13:28
1 * 4 != 14
take out the d-link
Unread 24-01-2011, 15:13
Will try that but does anyone else have any ideas, incase this doesn't work?
Unread 24-01-2011, 15:52
If you mean you entered your team number when you reformatted/reimaged the cRIO, that just told the cRIO what its IP address should be. It didn't give any information to LabVIEW about that address.
You also need to tell LabVIEW what IP address the cRIO has. When you created the project, there was a brief opportunity to enter that information. If you look at the Project Explorer window, the address should appear in parentheses at the right of the "RT CompactRIO Target" line (i.e. 10.13.07.02). If it's set to something like 10.xx.yy.02 instead, right-click the line and change the properties to the correct value.
Your programming computer should also have an IP address somewhere in the range 10.13.07.06 to 10.13.07.254, with 10.13.07.06 being the usual choice.
Unread 24-01-2011, 18:00
lscime lscime is offline
AKA: Luke Scime
FRC #2614 (Mountaineer Area RoboticS (MARS))
lscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to behold
Please see my post on this thread: http://www.chiefdelphi.com/forums/sh...threadid=89934
It includes instructions for a solution that has worked well for us.
Hope this helps and good luck,
-Luke
