Go to Post We design for being on a dysfunctional alliance: all the time. - boomergeek [more]
  #121   Spotlight this post!
Unread 22-01-2011, 06:41
George Nishimura's Avatar
George Nishimura George Nishimura is offline
Lurker
George Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud of
Re: why blame the programmers??
Originally Posted by tsa256 View Post
That would work great except, I currently hold head programmer, and electrical. So you can imagine I get all the blame.
Ditto. It's so much easier to combine the two.
Although 60% of the time it is electrical, so I can't really complain too much.
  #122   Spotlight this post!
Unread 22-01-2011, 09:16
riptide's Avatar
riptide riptide is offline
The Software Dude... LabView and VB
AKA: Jeff
FRC #1165 (Paradise)
riptide will become famous soon enough
Programmers in this competition are not real programmers in its true form. I would consider them electrical engineers as they are typically responsible for developing/interfacing the software and control systems to the hardware, which is typically built by the rest of the team. They are really the most critical member of the team. Without them the hunk of metal and plastic does nothing.
Like the real world, this person (usually only one) has the least amount of time to do their job because the hardware team went way over schedule to do the build.
Some helpful hints to keep the electrical engineer happy:
1. Don't ask the electrical engineer while they are programing DID YOU GET IT WORKING yet. It gets real frustrating after you get that question every two minutes from every team member. You will know it is working when you see it working.
2. Don't ask what are you doing when it looks like we are doing nothing. More than likely we are compiling or downloading the program to the robot. Or we are in deep logical thought on the best way to program and one question might just ruin that thought.
3. Don't take the robot from us while we are programming to make a tweak say it will only take two minutes, keep it for three hours, then ask us at the end of the day why it wasn't done.
4. If you want to learn how to program don't ask for someone to teach you in week 6 of the build.
5. Don't blame the electrical engineer/programmer for all the robot's issue. Just remember when you are pointing the finger you have three more pointing back at you. From my experience that is about the correct ratio of blame. Typically we only get 20% of the time to do 80% of the work. We get blamed for 80% of the problems when only about 20% of them are the programmers fault. Good old 80/20 rule.
Kidding aside,
If you are one of the electrical engineers, find a way to program and test without the hardware. If you don't have a spare robot the best method is to do a bench setup. Find a large table, get all the electrical components, tape them down and wire them up. For this setup use the smaller motors and attach a tape flag to the shaft so you can visually see the direction they are turning. Start programing.
Good Luck.
  #123   Spotlight this post!
Unread 24-01-2011, 09:47
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
As programmer I often get blamed with a lot of the errors on the robot. I find myself remembering what was said in Billy Joel's song Vienna "You know when your wrong but you don't always know when your right". I don't mind getting told that I messed up, because I probably did. What irks me is when I ask someone to check a system on the robot because I think it is electrical or mechanical and the rest of the team refuses to take five seconds to check, as well as prevent me from taking 5 seconds to stand up and look. That is without a doubt my biggest pet peeve of being a programmer. If you tell me I screwed up I'm more than happy to check, but that means that you should be nice enough to check when I say you screwed up. XD
Rant achieved.
"Don't worry, programming can fix it"
  #124   Spotlight this post!
Unread 24-01-2011, 10:35
iv1777 iv1777 is offline
FRC #1777
iv1777 is an unknown quantity at this point
If the code worked once, it will always work unless it has been changed, or something physical has changed on the robot - in which case it's mechanical problem, not programming....
  #125   Spotlight this post!
Unread 24-01-2011, 11:40
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
import time
time_code_was_changed = time.time()
if robot.is_changed() and robot.time_was_changed() > time_code_was_changed:
    print("Mechanical")
else:
    print("Programming")
  #126   Spotlight this post!
Unread 24-01-2011, 11:51
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Technically, if you are actually doing it like an actual control engineer would do things you have plenty of time. In all seriouness you shouldn't need the hardware to program the software. You do need the hardware to actually verify the programing is right but that should come after the robot is built.
Originally Posted by wireties View Post
And because the mechanical guys can't get it through their head that the robot itself is part of the servo feedback. The software can't be fully tested w/o working hardware - the gyro does not work while the robot is shaking itself apart - etc, etc, etc Classic comment: It works perfectly on the stand but not on the ground!! It has to be a software problem. Hehehe...
Once again. You should be able to figure out if the robot is going to shake itself apart long before it was actually built. Its a bad design process because you are risking having the robot rip itself apart to pieces. I always wonder why this sort of behavior gets by in a competition that is mentored by engineers. There isn't a single field of engineering that doesn't actually design their control systems like this.
  #127   Spotlight this post!
Unread 24-01-2011, 12:38
SudoSammich SudoSammich is offline
A pretty big deal...
AKA: Corey
FRC #0514 (Entropy)
SudoSammich is an unknown quantity at this point
That's a personal favorite of mine: The robot was working two hours ago, no code was changed, and now it's stopped: Clearly programming. At the '09 competition our feeding mechanism stopped working at times during the competition, and the coach kept coming back to me to "fix the code". On day three, we found a weld that was spaced 1" farther apart at the top of the robot than it should have been, completely stopping the part from functioning. Funny how that worked out.
  #128   Spotlight this post!
Unread 24-01-2011, 15:13
kaliken kaliken is offline
294 Old Fart Mentor...
AKA: Ken S
kaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant future
This reminds me of one of my first days in my job right out of college....
My lead went up to me and said half serious and half jokingly, "The most important thing to do at the start of a new project is to determine to whom to assign blame when things go wrong. Unfortunately this will have to be you!"
So really programmers you need to get on the act early and get the team to assign blame to mechanical earlier!!!!
Other great sayings.. "Don't worry we'll take care of this" "We" being the "Royal We' meaning X teamate will take care of it not me!
In all seriousness he was the best boss/mentor I could have had coming right out of college.
2010 World Champions! Newton Alliance Captain: Many thanks to 67 and 177 for the amazing ride
  #129   Spotlight this post!
Unread 24-01-2011, 18:24
hcps-maxwelltd hcps-maxwelltd is offline
AKA: timothy maxwell
FRC #0540 (talon 540)
hcps-maxwelltd is an unknown quantity at this point
i say if the programers are getting blamed they send the blame too the build team or electrical instead
  #130   Spotlight this post!
Unread 24-01-2011, 18:31
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
That doesn't work, they say we're trying to blame them for our flaws and tell us to fix our code.
GSR Dean's List Finalist 2011
  #131   Spotlight this post!
Unread 24-01-2011, 18:35
fyrefrost fyrefrost is offline
FRC #1245
fyrefrost is an unknown quantity at this point
the only people who blame the programmers are electrical. when they screw up the wiring.
  #132   Spotlight this post!
Unread 24-01-2011, 23:30
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
I've determined that all problems are mechanical. The programming is only an abstract idea without hardware and the hardware implements the programming, so everything is the fault of the hardware.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
  #133   Spotlight this post!
Unread 24-01-2011, 23:36
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
Today, I greased the gearboxes and tightened the chains on our robot because one side was slightly faster than the other, which is obviously a programming issue.
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
  #134   Spotlight this post!
Unread 26-01-2011, 03:58
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Why do all the electronics accuse the programmers.
Electronics are just looking at the diagram and plugging the cables in.
That's all they do ..
  #135   Spotlight this post!
Unread 26-01-2011, 06:35
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Electricity is a confounded thing you know. Especially since not everything conform to the same standards. Like how a set of wires provided for one sensor has a completely different arrangement and color meaning compared to another.
Improving the experience of programmers and the effectiveness of code kamocat Programming 18 25-12-2009 08:33
Placing Blame ExarKun666 Chit-Chat 17 24-04-2008 18:24
Who to blame for the creation of the Trackball. Chuck Glick General Forum 7 12-01-2008 22:35
I blame robotics for... JBotAlan Games/Trivia 12 05-12-2007 00:30
blame it on the doggy robot Andrew Rudolph Chit-Chat 0 26-10-2003 13:02
