Go to Post Age should not be a speed bump to creativity. - Greg Needel [more]
Unread 24-01-2011, 15:44
eStop Robotics's Avatar
eStop Robotics eStop Robotics is offline
Partner, eStop Robotics LLC
AKA: Joe Troy
eStop Robotics has a spectacular aura abouteStop Robotics has a spectacular aura abouteStop Robotics has a spectacular aura about
Re: Is the FIRST Touch PsoC Board the only option??
Greetings from eStop Robotics!
Many thanks to Jared for suggesting our new product the CCI (Custom Controls Interface)!!! The CCI can be used as an input device for the Drivers Station in addition to joysticks, gamepads, and the Cypress PsoC Board.
The CCI has 12 digital inputs and 4 analog inputs. No special SW or drivers to install. It works with your Driver Station PC out of the box. Your cRio programming is also no different than using a joystick, the same functions are used for the CCI as a regular usb joystick.
http://www.estoprobotics.com/estore/...d&productId=33
Good Luck to all the teams!!!
