Go to Post I've always believed that being who I was will not limit me to who I will be. That's what keeps me trying to learn more and become a better person. Otherwise I would've settled being someone ordinary and not care about anything around my life. - Ken Leung [more]
Unread 24-01-2011, 12:03
TomCerul TomCerul is offline
FRC #1493
TomCerul is an unknown quantity at this point
wifi radio theory
We're having some issues getting the wifi radios to talk to each other. What's the general configuration theory? Are both routers supposed to be bridges? Just one? Why would we run one as an access point at practice but as a bridge during competition? That violates my "Practice like you want to perform" rule.
The classmate can connect directly to the white DLink (ping) through the internal wifi card. I'm having a hard time understanding what the blue/black linksys is supposed to be doing at a high level though. I know it's supposed to provide better power for the classmate but is it acting as a bridge or what?
Thanks for you time!
Unread 24-01-2011, 13:33
Re: wifi radio theory
The 2011 wifi "standard" configuration uses just
  • the Classmate wireless
  • the white KOP D-Link on the robot (in AP mode)
Other configuration options exist depending on what you want to get out of life, but that's the basic setup.
At Competition we get the addition of the FMS Field AP, so we turn all our individual team APs into bridges instead.
If you want to "Practice like you want to perform," then you can add your old Linksys router to pretend to be the Field Router. It won't be the same of course, because the field setup uses different equipment and virtual private networks for each team, network switches between the Classmate and the Field Router, 60' of Ethernet cable, network monitoring software, and a Big Brother FMS, etc.
Unread 24-01-2011, 15:04
You should be using only the D-Link DAP-1522. Nothing more. If all your computers are capable of Wi-Fi, there should be no bridges. If you want to connect a wired-Ethernet-only computer, you can plug it into the DAP. If you want to add a bridge of your own, okay, but you're on your own for configuring it.
During competition, the access point is provided by the Field Management System. During development, there is no FMS, and the DAP must be in Access Point mode in order to connect the Driver Station to the robot.
Sure it can. If yours does not, there is likely a misconfiguration somewhere. Your D-Link DAP should be set in Access Point mode, with its SSID set to your team number, and wireless security disabled. The Driver Station software configures the Classmate networking appropriately, based on the team number you provide to it.
Last year's Linksys router is not used this year.
If you want to play around with alternate (and unsupported) network configurations, it should be possible to use the old blue Linksys as a fixed access point with your team number as its SSID on the 2.4 GHz band, configure the D-Link as a bridge to the wireless network thus created, and make sure everything is set to the appropriate IP addresses (similar to last year's setup). But you should first configure things as directed in the "How to" documents and get them to work the way they are supposed to, before starting any hacking.
Last edited by Alan Anderson : 24-01-2011 at 15:08. Reason: I wrote this post an hour and a half ago. It wasn't until just now that "networking problems" went away and let me post it.
Unread 24-01-2011, 15:50
Electrical Engineer
Rookie Year: 1995
Originally Posted by Alan Anderson View Post
... Your D-Link DAP should be set in Access Point mode, with its SSID set to your team number, and wireless security disabled...
Alan,
While I am sure that what you say will work, it is not what the teams were directed to do.
As per this document, they were instructed to enable WPA-AES security and enter a passphrase (see the attached picture). We used 3518WPAKEY as per the example. I told the students that we would be getting a different, random and unique passphrase at the competition.
If there contradicting instructions in a different document, I would appreciate it if you could post a link.
Thanks,
Mike
Name:	radio security.JPG
Mike Betts
As easy as 355/113...
Unread 24-01-2011, 16:14
That's only the first half of the instructions. It's specifically the "Configuring a radio for Competition" part. I don't know why it's in there, because it isn't how anyone is expected to use the system during development, and I think the settings should all be overwritten anyway when the kiosk does its stuff at competition.
The rest of the instructions, under the heading "Configuring a Radio for Access Point Use", tell you only to set the SSID and frequency band. The security remains disabled under AP mode.
Unread 24-01-2011, 16:59
Electrical Engineer
Rookie Year: 1995
Alan,
Because of your competence in such matters, I hate to disagree. But... It works just fine in AP mode when the WPA-AES is left on. You only have to enter your passphrase into the driver's station (and development station, if separate) and it works like a charm. This is our development configuration at Lecanto HS.
Nowhere did I see where WPA-AES was optional. The section it was in is titled "Configuring a radio for Competition:".
Regards,
Mike
Mike Betts
Unread 24-01-2011, 18:41
Clayton Yocom's Avatar
Clayton Yocom Clayton Yocom is offline
Programming Mentor
FRC #0027 (RUSH)
Clayton Yocom will become famous soon enoughClayton Yocom will become famous soon enough
Send a message via AIM to Clayton Yocom Send a message via MSN to Clayton Yocom Send a message via Yahoo to Clayton Yocom
To sound less blunt, the access point can be used with security, but any problems with it are less of a problem than to use without security. What is someone gonna do, access your cRIO? lol.
Unread 24-01-2011, 22:53
Having security on the D-Link in Access Point mode works fine, certainly. It's just not how the instructions tell you to set it up. I've not seen anything in the documentation that mentions having to enter a passphrase on the Driver Station computer.
Yes, the instructions call for WPA security when using the D-Link in Bridge mode. If you follow the instructions, however, you'll be using it that way only at a competition event.
Unread 25-01-2011, 09:53
FRC #1493
Very good, it sounds like we're all set already then. The classmate was talking to the DLink just fine. The students were under the impression that the classmate wouldn't have the range that we'd need for competition. As the the normal configuration is relying on the classmate, I'll defer to you guys and stop fighting with the linksys.
And thanks for the explaination about the competition AP. That makes a lot of sense.
Thank you!
Unread 25-01-2011, 10:12
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
When you are at the competition, you are connected directly to the Field Management System by a network cable. You will not be using your Classmate's wireless network during the competition.
The views expressed are mine and should not be construed to represent the views of anyone else.
