Go to Post Winning just makes your ego smile. - MooreteP [more]
Unread 24-01-2011, 16:55
Re: DLink 1522
Originally Posted by jeleser View Post
Alright, so we can't get past the step where you change your settings in bridge mode. I know your post is pretty straight-forward, but I just wanted to double check that we in fact do not need bridge mode?
You won't be using your DAP as a bridge until you go to a competition event. If things go as I expect them to, there will be an automated "FRC Radio Kiosk" that will set up everything for you.
Because when we try to change the settings in IE, it saves the settings for Wireless, but not for Network.
How do you know it isn't saving the settings? If it's just a matter of failing to show you a confirmation screen, that's easy to explain -- you've just changed the DAP's address, but your computer is still trying to connect to the original address.
Tl;dr: We can just get away without setting up bridge mode?
You don't need to set up bridge mode for development at home. You won't be using it that way (unless you do some fancy undocumented networking setup using other equipment that might work okay but is neither supported nor sanctioned this year).
