Go to Post Thank you lord I knew there was a reason I got 10 books on autonomous robotics. - Adam Y. [more]
Unread 24-01-2011, 17:27
unionylibertad's Avatar
unionylibertad unionylibertad is offline
unionylibertad is an unknown quantity at this point
other robotics competitions similar to FRC
ive seen a lot of VEX- (eg BEST, botball) sized comps, but nothing on the scale of FRC
is there anything else similar to FRC anywhere?
Unread 24-01-2011, 17:36
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: other robotics competitions similar to FRC
http://robots.net/rcfaq.html
Unread 24-01-2011, 17:41
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
This thread should provide the information you need.
Unread 24-01-2011, 17:47
Dracon Phinex's Avatar
Dracon Phinex Dracon Phinex is offline
AKA: Daniel Wright
FRC #3130 (ERRORs)
Team Role: Team Spirit / Cheering
Dracon Phinex is an unknown quantity at this point
Lightbulb Re: other robotics competitions similar to FRC
Isn't there FTC and FLL?
Unread 24-01-2011, 17:53
Not in terms of size and scale. FRC robots are file-cabinet sized or so. FTC and FLL robots fit into file cabinets rather easily.
Collegiate FIRST should be kind of similar to FRC in terms of scale and complexity, when it gets going. Not quite sure about sheer size, but then again flying devices need to be smallish if they're for indoor use.
Oh, and there's always Battlebots. (AKA the #1 most common point of reference for the uninitiated.)
