Go to Post Sleep... what is this sleep you speak of? - Choi9111 [more]
Unread 24-01-2011, 17:52
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Victor controls
I'm attempting to make drive code for our robot currently. We are planning to have our main drive run on a tank control, and our side drive mechanism run on the x-axis of the right hand stick after the right hand stick's trigger has been activated.
We're planning to use a victor for the side drive (a single motor). Would you use the Set method to run it or can you even control a victor via control if it's not a RobotDrive declaration? Relevant current code below.
TY in advance.
class RobotDemo : public SimpleRobot
	RobotDrive maindrive; // main drive system
	Victor crab; // sideways drive system
	Joystick stickone; // right joystick
	Joystick sticktwo; // left joystick
public:
	RobotDemo(void):
		// These must be initialized in the same order
		// as they are declared above.
		maindrive(1, 2),
		crab(3),
		stickone(1),
		sticktwo(2)
if (stickone.GetTrigger())
				crab.Set(stickone.GetX);
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 24-01-2011, 18:28
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Victor controls
Yes, you can use Set(), even if it is not part of your drive system.
Also, make sure you include that code in your teleop loop.
crab.Set(stickone.GetX()) <- And include a () after GetX
Unread 24-01-2011, 18:58
Zuelu562's Avatar
AKA: Jake Janssens
Re: Victor controls
Thanks, i forgot the parenthesis.
Team Resume
Volunteer Resume:
