Go to Post You know you've made it big when people assume every imperfection is genius! - araniaraniratul [more]
Unread 24-01-2011, 18:07
paul dixon paul dixon is offline
FRC #3626
paul dixon is an unknown quantity at this point
SUPER SHIFTER
Hello fellow firsters, I was inquiring about a problem we have encountered with the super shifters. These super shifters are the gearboxes ordered from AndyMark.com. (http://www.andymark.com/ProductDetai...ctCode=AM-0114) Putting everything together was pretty easy but it seems that there is no built in way to mount the shifter to the robot, and I was wondering if you guys have any suggestions on how we should go about doing this!
Thanks,
Paul D.
Unread 24-01-2011, 18:11
EagleEngineer's Avatar
EagleEngineer EagleEngineer is offline
AKA: Michael Amoun
FRC #1138 (Eagle Engineering)
EagleEngineer is an unknown quantity at this point
Re: SUPER SHIFTER
our teams is using the same gearbox, and we are going to have a custom piece made for the gearbox. You can also use the C-bases connector, from the 2010 kitbot.
Unread 24-01-2011, 18:31
earlybird's Avatar
earlybird earlybird is offline
They tried to ship me 2 competition
AKA: Robbie Oehrli
FRC #2849 (Team Ursa Major)
earlybird is a jewel in the roughearlybird is a jewel in the roughearlybird is a jewel in the rough
Re: SUPER SHIFTER
My team also uses super shifters. We just use the same bolts that hold the box together to mount it to the drive base. We typically make our drive base out of C channel that is the same height as the super shifters and get it machined so it all fits nicely.
Unread 24-01-2011, 19:03
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: SUPER SHIFTER
Use these two mounting brackets to mount the super shifters to the base, you install the SS the same way as a regular tough box.
L-bracket-http://www.andymark.com/productdetails.asp?productcode=am-0204
Brace-http://www.andymark.com/productdetails.asp?productcode=am-0203
WARNING these do NOT come with hardware so you have to use your own or by some at a home depot or lowes.
Unread 24-01-2011, 20:30
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: SUPER SHIFTER
We've replaced 2 of the bolts that hold together the gearbox with longer 1/4-20 bolts that also go through mounts to the drive train.
I'd recommend you keep the black shroud on the SS if this is your first time mounting it -- doing so will ensure your gearbox doesn't bind if you don't fully support it properly.
Unread 25-01-2011, 10:06
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: SUPER SHIFTER
I referenced AM's Pre-Setup Super Shifter Chassis which is based on the C-Base and they use the Brackets below for mounting.
http://www.andymark.com/productdetai...ctcode=am-0204
http://www.andymark.com/ProductDetai...ctCode=am-0203
Here is the setup I referenced so you can see the parts in place: http://www.andymark.com/ProductDetai...ctCode=am-0484
-Dustin Benedict
