Go to Post FIRST isn't about building robots. I know. But I also know that Inspiration comes in a lot of flavors and I, for one, believe it is a lot easier to inspire my kids when we set "playing after lunch on Saturday" as a worthy team goal. - Joe Johnson [more]
Unread 24-01-2011, 19:34
takiko1996's Avatar
takiko1996 takiko1996 is offline
FRC #2443 (Blue Thunder)
takiko1996 is an unknown quantity at this point
Mini Robot
Will your team get DQ if Your Mini Robot is still moving after the time has run out?
Unread 24-01-2011, 19:39
rutzman rutzman is offline
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
Re: Mini Robot
No.
Unread 24-01-2011, 19:40
zjagoda's Avatar
zjagoda zjagoda is offline
Animation worker
FRC #2456
Team Role: Animator
zjagoda is an unknown quantity at this point
Re: Mini Robot
you don't get DQ but if it doesn't come down after a minute it will most ikely be chainsawed off the pole.
hope this helps.
Unread 24-01-2011, 19:41
takiko1996's Avatar
Re: Mini Robot
How do you know you wont get dq? How do you know your robot will get chainsawed?
Unread 24-01-2011, 19:48
AKA: Ryan
FRC #2614 (MARS)
Re: Mini Robot
Nowhere in the manual does it say that your minibot has to stop moving at the end of the match, let alone that it would cause disqualification.
"Chainsawed" shouldn't be taken literally. Look at rule <G59> for more information on minibot retrieval.
Unread 24-01-2011, 19:52
Re: Mini Robot
You will not get a DQ if you're moving upwards. There is no penalty listed for not stopping upward motion after the end of the match--after all, the minibot doesn't know it's the end of the match.
zjagoda, you may wish to re-read the Manual. Specifically, <G59>. The Field Crew will retrieve the Minibot if the teams do not. How they do that is kind of their option, and no guarantees are made as to Minibot safety/integrity after return to earth. A second call for the field crew to retrieve it is a Yellow Card. Two Yellow Cards is one Red Card or DQ.
Unread 24-01-2011, 19:57
Chris is me's Avatar
AKA: Pinecone
Re: Mini Robot
I wonder if you could have teammates sit on other's shoulders to reach that high? That or climb up on the platform and reach.
Unread 24-01-2011, 19:58
Electrical Engineer
Rookie Year: 1995
Re: Mini Robot
Unless your robot is destroying the pipe or other field elements, no DQ.
Now, the chainsaw statement was a little harsh...
<R94> The MINIBOT must be designed such that it can easily be removed from the TOWER at the end of the MATCH.
This means that if your robot is going to stay at the top of the pole until retrieved, you have problems. The competitions have very short cycle times. You will have 10 or 15 seconds to remove your robot. You will not be allowed to bring ladders into the field to remove your minibot. If the field crew needs to "assist" you in removing your minibot, they may break it in the process.
Do yourself a favor and insure that your robot is easily removed...
Regards,
Mike
Mike Betts
As easy as 355/113...
