Go to Post Every single person on the team, read the manual, cover to cover, NO skimming. Do not give the task of knowing the rules to a few people. Do not pass go, do not collect $200, READ THE MANUAL. - RoboChair [more]
Unread 24-01-2011, 19:23
AMFof306 AMFof306 is offline
FRC #0306
AMFof306 is an unknown quantity at this point
Exclamation Whats going on
We have connection and robot code, we have a program and everything looks to be wired correctly. Therefore, I would expect everything to run smoothly but the status lights on our Jaguars are yellow and blinking so there is something wrong somewhere, but no clue where. Any one got some advice, we are using LabVIEW if that's necessary info.
Unread 24-01-2011, 19:44
Re: Whats going on
Did you enable the robot from the driver station?
Unread 24-01-2011, 19:49
FRC #0306
Re: Whats going on
Yes, and it showed the green "lights" saying communication and robot code were present
Unread 24-01-2011, 19:52
AgataSays AgataSays is offline
FRC #3553
AgataSays is an unknown quantity at this point
Re: Whats going on
blinking lights mean no signal.
check to make sure the pwm cables are not flipped and that your sidecar is plugged into port 4 not the secondary port
Unread 24-01-2011, 20:00
FRC #0306
Re: Whats going on
Umm what do you mean by port 4, like on the cRIO or what?
Unread 24-01-2011, 20:07
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Re: Whats going on
Yes.
Slot 1 MUST have an analog module w/ breakout and jumper
slot 2 MAY have an analog module w/ breakout
slot 4 MUST have a digital module w/ sidecar
slot6 MAY have a digital module w/ sidecar
slot 7&8 MAY have solenoid modules in them
also check that you have power to the digital sidecar in addition to making sure the PWM is in the right way.
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 24-01-2011, 20:11
FRC #0306
Re: Whats going on
Okay, that worked. thank you very much I was not aware of those requirements.
