Go to Post Beatings will continue until morale improves! - DampRobot [more]
Unread 24-01-2011, 21:52
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Best way of stopping the robot?
For the IterativeRobot I decided to force the robot to stop if it is in disabled mode or if the motorsafety gets disabled/timeout.
First of all, will motorsafety automatically shutdown motors if it isn't fed or enabled? If so then I probably should remove my lines telling the motors to stop.
Secondly, does it really matter which way you stop the robot? For instance, there are two different ways I know of to stop the robot. use the stopMotor method or tell the motors to move at a speed of 0 and turn of 0. If the stopMotor does not now allow you to use the motors until the robot is reset then I would use the method of setting the motor to speed and turn 0.
Unread 25-01-2011, 01:25
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Best way of stopping the robot?
The whole point of the Motor Safety feature is to stop the motors if you don't set them often enough. If you disable the Motor Safety, that does not disable the motors, it disables the safety... i.e. the motors will continue to run even if you don't update them often enough.
I couldn't tell from your post if you were considering disabling the robot or E-Stopping the robot as options for stopping the motors.
-Joe
Unread 26-01-2011, 20:16
wdell wdell is offline
AKA: William Dell
FRC #3999 (Shadetree Mechanics)
wdell has a spectacular aura aboutwdell has a spectacular aura about
Sledgehammer? Always stops our runaways...
Unread 26-01-2011, 21:11
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Our robot stops the instant we click the Disable button. Does it not do that for you?
Unread 26-01-2011, 21:17
The space bar on the Driver Station computer is an even more convenient way to hit disable.
