Go to Post "Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world." - Albert Einstein - Edward Debler [more]
Unread 24-01-2011, 22:20
MattCarey3625's Avatar
MattCarey3625 MattCarey3625 is offline
#3625 Programming and Wiring Head
FRC #3625 (Some Assembly Required)
MattCarey3625 is an unknown quantity at this point
Drive Function (Complete Rookie)
Hello, I'm sorry if there is a post like this already, although I looked and saw none. I am just now starting to understand LabVIEW and we have just gotten a working program for motor controll but how do we use a Drive Function or use multiple motors at once? I tried and what I came up with is the attached. I have tried the LVMastery but I find it hard to learn from. Thank you for any responses.
matt@hp-mini-110$> sudo make robot
sudo pass for matt:
unable to make robot
Unread 24-01-2011, 22:59
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
Re: Drive Function (Complete Rookie)
Do this:
(1) Right click on block diagram
(2) Choose WPI Robotics Library
(3) Robot Drive
(4) Choose which ever you want (open two motors or four motors etc.)
If you are using 4 wheel drive(normal wheels), choose Arcade Drive
Hope it helped
"A team back in training !"
Unread 25-01-2011, 17:31
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
what he said.
Unread 26-01-2011, 13:52
varun1718's Avatar
varun1718 varun1718 is offline
ToaD
AKA: Varun Jasuja
FRC #1669 (Jaganators)
varun1718 is an unknown quantity at this point
Send a message via AIM to varun1718
If the in-built drive functions are too complicated for you, Use the Motor VIs from the Actuators part of WPI Library. You can set up individual motors this way and build your own drive system.
I did that my rookie year just to see how the drive function worked.
Unread 26-01-2011, 14:43
Thanks for replies. I got a motor program up without using the sets for 1 joystick turn controll. Thank you though!
sudo pass for matt:
Unread 26-01-2011, 15:43
Wolfgang Wolfgang is offline
AKA: Mehmed
FRC #1245 (Shazbots)
Wolfgang is an unknown quantity at this point
You need to decide whether you are using arcade drive or tank drive (or something else). For arcade drive, you need to open up the arcade drive vi and wire in the joystick you will use and such. For tank drive, use the tank drive vi and open 2 joysticks. Wire the ONLY the y axes of the joysticks to the tank drive axes inputs. It's probably a little difficult to read this, but I hope this helps!
Unread 26-01-2011, 23:06
Today I coded the attached VI. Is the arcade drive function do what this does? If so I should probably use that and shorten the code.
sudo pass for matt:
Unread 27-01-2011, 11:05
Clayton Yocom's Avatar
Clayton Yocom Clayton Yocom is offline
Programming Mentor
FRC #0027 (RUSH)
Clayton Yocom will become famous soon enoughClayton Yocom will become famous soon enough
Send a message via AIM to Clayton Yocom Send a message via MSN to Clayton Yocom Send a message via Yahoo to Clayton Yocom
Yes, this is what arcade drive does, here and here are what you really need to try to duplicate.
Both of those are actually in the FRC cRIO Robot Project framework that you can use in labview. (in wpi robotics library there are open 2 motors and open 4 motors btw, which will then map them to a single referum name then arcade drive can address both of them. )
