Go to Post The best teams have students who genuinely enjoy scouting and the alliance selection process. - Jay O'Donnell [more]
Unread 24-01-2011, 22:33
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Wink Re: Legality of Fiberglass as a building material?
Originally Posted by 548swimmer View Post
Little bit heavy, but otherwise awesome!
They make it in different thicknesses, and the 1/8" stuff is strong and light. We've used it too. I hear it also works for arms?
Unread 24-01-2011, 22:51
Team 2811's Avatar
Team 2811 Team 2811 is offline
WHAT DID YOU DO!? ..umm... whoops!
AKA: Ian Heffron
FRC #2811 (Stormbots)
Team Role: Electrical
Team 2811 is on a distinguished road
Fiberglass is very easy to break and if it does, you will have to take all of the rest of the fiberglass off. Then you will have to replace it. If this happens multiple times, the cost will really add up.
Just my advice. My team tried using fibergalss in 2009 during Lunacy. It was constantly breaking and we needed to replace it often. This really added up in our costs.
Good luck
Its about a day out!
Once, there were two marshmallows roasting over a campfire.
First marshmallow, "It is really hot up here."
Second marshmallow, "OH MY GOD ITS A TALKING MARSHMALLOW!!!"
The more you learn the more you know
The more you know the more you forget
The more you forget the less you know
So why learn?
Unread 24-01-2011, 22:52
MrForbes's Avatar
AKA: Jim
Interesting, we used it for our chassis for 3 years and never had these problems. I guess it depends on how you design your robot....you have to use fiberglass in appropriate places, and design the thing properly, then it works fine. Like any other material, I suppose.
Unread 24-01-2011, 23:53
Gdeaver Gdeaver is online now
FRC #1640
It's all in the design, choice of material and construction techniques. We have made many light weight and durable arms from pultrusions. Never had a failure. I have seen many AL arms eat them selves. I have seen teams use poor construction methods with Pultrusions and watch them fail.
Unread 25-01-2011, 01:30
Same here, we've used it in simple but effective applications on our 2008 arm.
Machining/drilling holes in fiberglass is the only hassle. Masks and gloves along with goggles
Unread 25-01-2011, 00:41
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Where can one acquire these materials from?
Unread 25-01-2011, 09:54
MrForbes's Avatar
AKA: Jim
See post #6 in this thread. Generally it's a good idea to read all the posts in a thread, before asking a question about the subject.
Unread 25-01-2011, 10:22
Peggy Painter Peggy Painter is offline
Catalyst
FRC #5476 (Y Bridge 4H Robotics)
Peggy Painter has much to be proud ofPeggy Painter has much to be proud ofPeggy Painter has much to be proud ofPeggy Painter has much to be proud ofPeggy Painter has much to be proud ofPeggy Painter has much to be proud ofPeggy Painter has much to be proud ofPeggy Painter has much to be proud of
I wondered that myself. Several years ago, I build a 21 ft long, triple seated kayak from plywood & epoxy & fiberglass---very strong and it only weighed 45 pounds.
It was great fun to see the looks on people's faces when we would arrive at the lake and my 7yo dd & I unloaded it from the roof of our minivan by ourselves. Just had be careful on windy days!
Unread 25-01-2011, 15:48
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
My mistake, I thought you were referring to depleted uranium...
Unread 25-01-2011, 17:50
FRC #1640
The Bedford material is available from both MSC and McMaster Carr in the volume teams would need. McMaster search raw materials - plastics - Fiberglass and you'll find it.
Unread 25-01-2011, 18:23
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
We have been using Fiberglass since 2001 on all our bots. Never had splintering, or any serious breakage for that matter. I wonder if people with these problems are using pultruded fiberglass?
Its 1/3 the weight of aluminum and 1/5 the weight of steel for the same strength.
www.creativepultrusions.com
Faridodin "Fredi" Lajvardi KD7WKD
