Go to Post Your not a robot (and they aren't perfect either) - Conor Ryan [more]
Unread 24-01-2011, 20:01
Team3189p Team3189p is offline
Team 3189
AKA: James W.
FRC #3189 (Curcuit Breakers)
Team3189p is an unknown quantity at this point
Best amount of sprocket teeth
We are optimizing our drive train and we would like to see your opinion on the best amount of teeth on a sprocket for a 6WD drive train.
We have right now 26 and 12 teeth...
Unread 24-01-2011, 20:14
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Best amount of sprocket teeth
James,
It may help to provide some other details about your drive train such as # of motors and diameter of your wheels. Generally, there is more to it than the sprocket reduction after the gearbox. To help you, JVN from 148 updates his calculator every year. Play with the #'s so they match what's on your robot, and tell us what your final speed is. Be careful when gearing for high speed though -- there IS a trade-off.
Finally, don't let anyone tell you that 2 CIMs on a drive train is a bad idea -- if it's geared properly, it works just fine (and you can still be very successful).
Unread 24-01-2011, 22:54
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
After you've found the desired ratio, use as few teeth as possible so that the weight remains low.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 24-01-2011, 23:35
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Or use as many teeth as possible so the stress in the chain remains low.
Unread 24-01-2011, 23:51
Bob Steele's Avatar
AKA: Bob Steele
Remember its not really about the number of teeth.. its about the diameter of the gear.
In matched gears this can be equated to the number of teeth.
You want to figure out the ratio you need between motor and output and then figure out a way to get that mechanical advantage...
You don't have to use gears or teeth at all..you may also have to use several gears to get where you want..(ie gear box..)
Better to think of it as the ratio you want...and not the number of teeth...
Good luck with your design!!
Unread 25-01-2011, 00:38
Chris is me's Avatar
AKA: Pinecone
I'm going to go ahead and do that - "geared properly" for a 2 CIM drive with Kit wheels is under 8 feet per second - not very fast.
Unread 25-01-2011, 01:24
BornaE's Avatar
BornaE BornaE is online now
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
not sure where you got your number. 4.7:1 gearbox and 2.1:1 sprocket ratio and 6 inch wheels gives you a 13 feet per second top speed.
-Borna Emami
Team 0x27
Unread 25-01-2011, 01:32
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
2 CIM's can be very effective. My team's rookie year (2007), we were highest rookie seed, and one of the more effective defensive bots. You don't need to have a ton of pushing force to be a good bot (offensive or defensive).
4CIM's is no doubt going to produce a stronger drivetrain.
Everything is a trade off. 4 CIM drivetrain=more pushing ability, but no CIMs are available for other purposes. 2 CIM drivetrain=not pushing anybody around the field, but those 2 motors are freed up to work elsewhere.
I won't even get into 2009 where less was actually more.
Unread 28-01-2011, 20:26
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Make sure your chain catches at least 120 degreees of every sprocket. And in general tooth/diameter ratios of more than 3:1 are problematic.
Beyond that just choose sprockets that fit and give you the gear ratio to generate the required torque and/or speed.
Unread 28-01-2011, 20:29
AKA: Pinecone
I am saying that is not a proper gear ratio for a good performing drive with only 2 CIMs. Of course it is technically feasible with the KoP to gear a CIM faster - I just don't think you'll really be able to do anything over 8 FPS.
4 CIM drivetrains, plz
Unread 28-01-2011, 20:35
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
4 vs 2 CIM's is not about pushing power. It's about available torque and how you choose to use that torque. You can gear for speed with 2 but will you ever be able to reach that speed, or you can gear for power but can you effectively be able to get the motors spinning up fast enough to apply that power?
