Go to Post Putting 2 and 2 together, and then mixing them back up for someone else to try and get 4 in a different way is just plain fun. - Elgin Clock [more]
Unread 24-01-2011, 22:33
spidey619 spidey619 is offline
FRC #1796
spidey619 is an unknown quantity at this point
Exclamation Slowing Down Motor On Java
I am a new person to the world of java and i have stumbled on to a problem. When trying to program a prototype arm it goes to fast.
How can i reduce the speed without changing the arm itself?
Unread 25-01-2011, 01:27
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Slowing Down Motor On Java
Just divide the number you are sending to the set() function by some number greater than 1.
Unread 26-01-2011, 20:22
germansamurai16's Avatar
germansamurai16 germansamurai16 is offline
AKA: Jonathan Nagel
FRC #0224 (The Tribe)
germansamurai16 is on a distinguished road
Send a message via AIM to germansamurai16 Send a message via MSN to germansamurai16 Send a message via Yahoo to germansamurai16
the code looks for a magnitude value from the controller that ranges from -1 to 1. like jhersh said, divide by some number.
2 would give half speed, for the best results if 2 is too large move the number by increments of .5
--Nagel
Unread 26-01-2011, 22:30
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Are you using a Jaguar? A Victor? or a Spike?
Unread 26-01-2011, 22:46
FRC #1796
Currently i am using a victor to control the arm system.
Unread 26-01-2011, 22:55
AKA: Bryant
So based on what you said I am assuming you are doing something along this line
Victor a_motor = new Victor(1);
a_motor.set(1);
If you wanted to go slower you would want a percentage of the power so for example 25% power
a_motor.set(0.25);
Unread 28-01-2011, 21:38
FRC #1796
okay yayyyy it worked so awesome.............
but now i have a situation which is causing me a headache.
how can i control the motor, using the victor, going forward and reverse using different buttons on the joystick cause i need the arm to go up and down.
Thanks so much for your help people i really appreciate it.
Unread 30-01-2011, 20:15
AKA: Bryant
Set the value to a negative number for reverse direction
e.g. set (0.5) for 50% forward and set(-0.5) for 50% reverse
Unread 31-01-2011, 10:49
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Thats easy
Replace # with the button numbers and motor with your victor
if (joystick.getRawButton(#) == true)
motor.set(0.25)
else
motor.set(0.0)
motor.set(-0.25)
else
motor.set(0.0)
Programmer Matt,
Gus Robotics, team228.org
