Go to Post Contrary to the term, common sense isn't all that common. - RoboChair [more]
Unread 25-01-2011, 01:22
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Reading File off Dashboard on cRIO
Is it possible to read a file that is on the drivers station on the cRIO? We have an idea that would make an amazing autonomous but we would need to read a file that is on the drivers station since we can't store it on the cRIO.
Unread 25-01-2011, 07:55
Re: Reading File off Dashboard on cRIO
It is possible store files on the cRIO. You can update the build step to include the file in the data directory, or you can ftp the file.
You also need to write the code on the cRIO to open and read the file contents. One issue with that is making sure you use the correct path.
Greg McKaskle
