Go to Post (OK, now that I have said this, just watch someone like Kevin Watson have a working solution by this Friday... :yikes: ) - dlavery [more]
Unread 25-01-2011, 10:31
Dave Bush Dave Bush is offline
FRC #0801
Dave Bush is an unknown quantity at this point
Closed Loop Jag with 2x Motor & 1x Encoder
Looking for advice and wisdom on setting up our drive system. We have two motors geared together on each drive side and one encoder on each side. We would like to use Jags in Velocity mode, but of course rules require 1 Jag per motor. How do we get closed loop control to both Jags from 1 encoder? Is the solution as simple as building a Y cable from the encoder to the Jags so that they are getting the same feedback? Or are there problems with this?
Thanks,
Dave Bush
Programmer Team 801
Unread 25-01-2011, 10:48
Re: Closed Loop Jag with 2x Motor & 1x Encoder
The 1 encoder, 2 jaguars thread has some ideas.
Unread 25-01-2011, 12:24
FRC #0801
Thanks for the pointer! Unfortunately, it doesn't look like a simple answer.
