Go to Post "And that right there is the Sharpie line between right and wrong. Guess which side you cut on?" - Cypher [more]
Unread 19-02-2010, 19:42
just_wondering just_wondering is offline
Newbie :)
FRC #3202 (Knightbots)
just_wondering is an unknown quantity at this point
Exclamation Compressor Error
What does this error mean?
ERROR <Code> -2206 occurred at RT FIFO Read in Compressor.lvlib:GetEnableState.vi->Teleop.vi->Robot Main.viV
Unread 19-02-2010, 19:44
Wolfgang Wolfgang is offline
AKA: Mehmed
FRC #1245 (Shazbots)
Wolfgang is an unknown quantity at this point
Re: Compressor Error
Are you using 'open compressor' or 'get compressor refnum'? I was told by people in my team to use refnum. The refnum is Compresser. Just that. Otherwise, I am not sure what it is.
Unread 19-02-2010, 23:13
Newbie :)
refnum. it is opened in Begin.vi
Unread 19-02-2010, 23:38
It would be helpful if you posted your begin.vi and telop.vi.
Unread 20-02-2010, 20:02
Newbie :)
Talking Re: Compressor Error
so, apparently the spike relay had blown a fuse, thanks anyway you guys
Unread 20-02-2010, 20:14
See <R60-I> so that this doesn't happen again, since the compressor has a large start-up current.
However, it seems unlikely that a blown fuse in the spike would cause the error that you posted.
Unread 25-01-2011, 08:04
sdrilling sdrilling is offline
FRC #2239
sdrilling is an unknown quantity at this point
I have also seen this error. What else would cause the RT FIFO error besides the blown fuse?
Thanks.
Unread 25-01-2011, 13:27
Post the code and the error message.
The OP error message hinted that they had the Compressor code in the wrong location (Teleop.vi).
The Compressor code all goes in Begin.vi with a Close in Finish.vi.
Compressor Code causes No Robot Code Error sircedric4 C/C++ 25 03-02-2010 10:13
MPLAB error: Error [1027] unable to locate 'serial_ports.h' rokenboker Programming 10 03-09-2009 16:29
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
Compressor Flowrate Error in Catalog Raul Pneumatics 1 04-02-2004 20:44
