Go to Post "Dear Santa, all I want for Christmas is a game hint." - Gregor [more]
Unread 25-01-2011, 13:30
dwodrich dwodrich is offline
FRC #1706
dwodrich has a spectacular aura aboutdwodrich has a spectacular aura aboutdwodrich has a spectacular aura about
Potentiometer or Encoder?
We are considering using a potentiometer or an encoder for precise possisioning of our arm. We believe the endocder offers greater precision because of the number of counts per revolution. the potentiometer would be hooked to an arm joint and the digital encoder would be on a gear.
Assuming mounting them is a wash, any other pros or cons anyone can think of?
Unread 25-01-2011, 13:55
Re: Potentiometer or Encoder?
A potentiometer gives you an absolute indication of position. You don't have to get things to a known position and reset a count before you can control it properly. If you use a good-quality pot and take care to route your wires so you don't introduce a lot of noise on the sensor signal, you can get ten bits of resolution easily. That's the equivalent of more than 1000 steps. For a simple arm, the mechanical "slop" is likely to be more than the measurement resolution.
An encoder is perhaps more repeatable, and has the possibility of being more precise, but both require that you know exactly where it started.
You might consider using an absolute magnetic encoder instead of a potentiometer. You can get the same information from them, but the magnetic encoder won't get noisy or develop dead spots the way a pot can. Two of them were provided in the Kit of Parts this year.
