Go to Post In my opinion, if it can light a fire in your heart to burn with passion, and you can maintain that fine line between passionate and crazy; then go for it. Power to Passion. - RKElectricalman [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.50 average. Display Modes
Unread 25-01-2011, 14:25
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Minibot climb rate
Originally Posted by Gary Dillard View Post
So you can see that for a robot less than 5 pounds, even including some inefficiencies 3 seconds is absolutely feasible.
Check your math. The short story is -- equations only tell us where to start with MINIBOT prototyping, yet only real prototypes will tell us if the theory is sound.
The problem with such simple Power->Torque conversion in this case is that it does not account for the increased time the MINIBOT will take to get to its max speed under a higher torque load. Kinematic equations are non-linear with that respect when combined with the inverse relationship of an electric motor's speed-versus-torque relationship, thus analyzing a distance-versus-time chart between the two options may surprise you.
The problem is, distance-versus-time isn't quite as straight forward as it seems. In my analysis, I have to piecewise the graphs into acceleration sections and max-speed sections based upon the calculated time it take to accelerate to max speed under load.
So while I don't claim to have my calculations be 100% precise to real-world conditions, they do show that MINIBOTS with a 0.5:1 ratio with 4" wheels and a 5-lbs of weight will spend over 75% of their climb time in the acceleration phase, resulting in a 6+ second climb. 0.5:1 ratios with 3" wheels have 4-4.5 second climbs (50% of which is acceleration). Direct-drive 4" wheels have about the same times due to greater efficiency motor-to-pole coupled with less mass due to no gearing (all else equal), even though its max speed is technically slower than 0.5:1x3" wheels on a flat field.
...or they are direct driving but with that said you direct drive the motors get really close to stalling after only a few pounds
Actually, putting a 0.5:1 ratio on the MINIBOT puts it's torque load twice as close (ish) to stall as direct drive does.
