Go to Post If nothing's going wrong, then there is something seriously wrong. - Astronouth7303 [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.50 average. Display Modes
  #121   Spotlight this post!
Unread 24-01-2011, 23:36
PVCMike PVCMike is offline
AKA: Mike Jr.
FRC #1058 (PVC Pirates)
PVCMike has a spectacular aura aboutPVCMike has a spectacular aura aboutPVCMike has a spectacular aura about
Re: Minibot climb rate
I too am curious to know what the sub 3 second mini-bots are using for gearing. Thank you to the few people who shared videos! No proof like video!
Coming up on year 15 with the PVC Pirates!: www.team1058.com
https://www.thebluealliance.com/team/1058
  #122   Spotlight this post!
Unread 25-01-2011, 05:49
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Originally Posted by rbaker8734 View Post
I think that you are forgetting about torque!!!
And gravity!
  #123   Spotlight this post!
Unread 25-01-2011, 13:21
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Can anyone give hints on haw to make the climb rate as fast as possible any ideas will bee much appriciated
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
  #124   Spotlight this post!
Unread 25-01-2011, 13:29
liam.larkin's Avatar
liam.larkin liam.larkin is offline
We will find a way or make one!!
FRC #0272 (Cyber Crusaders)
liam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to behold
Some quick math and some analysis of the torque/stall curves for the motors have shown us that the most optimal gearing rate is .5/1 please check my math. Additionally using this gearing rate we found that a robot if carefully constructed can weight about 5-6 pounds. This gets you to the top in about 4.0-4.75 seconds. This has been pretty much confirmed by our present prototype minibot design.
These individuals claiming 2-3 seconds I have questioned unless the robot is like 3 pounds or they are direct driving but with that said you direct drive the motors get really close to stalling after only a few pounds. I would love to see a video of a team beating 4.0 seconds
  #125   Spotlight this post!
Unread 25-01-2011, 13:34
cmass cmass is offline
FRC #1189
cmass is an unknown quantity at this point
your 5-6 pounds is way wrong.
Start with only what you need and then make that lighter. I'm certain that 4# is possible and teams will do better than that.
With standard out of the kit parts and not modified we got to 3 seconds and < 5#.
You are missing something.
  #126   Spotlight this post!
Unread 25-01-2011, 13:38
FRC #1189
Originally Posted by klmx30302 View Post
With 4" wheels the motors will backdrive easily, the way we get ours down is by putting some long bolts on the bottomside of the robot. next get a pole and attach a ziptie in a large loop at the top, use it to gently pull on the bottom of the minibot and it should backdrive all the way down.
Here is a video of our minibot prototype:
http://www.youtube.com/watch?v=8IKLSgfXqcM
No ladders, no poles on the field, look at the Q&A forum. Keep working!
  #127   Spotlight this post!
Unread 25-01-2011, 14:00
Generator of Entropy
FRC #2973 (The Mad Rockers)
OK let me check your math, 2 ways
Suppose your minibot weighs 5 pounds, you use 2 motors with a .5:1 gear ratio, and you use 4 inch diameter wheels (using nominal numbers and ignoring start up and inefficiencies for now). The robot exerts a torque on the wheel of 10 inch pounds (weight times radius), and the gear ratio makes the torque on the motors 20 inch pounds, or 10 inch pounds on each motor. Looking at the motor curve, they run at 77.8 rpm at 10 inch pounds load (sorry, I always work in English units). 77.8 rpm on the motor divided by the gear ratio and divided by 60 gives you 2.593 revs per second at the wheel, times pi times the diameter gives you 33 inches per second up the pole. If you start at the top of the line (30 inches off of the floor) you have to travel 92.25 inches (122 minus 30 plus 1/4), which equals 2.83 seconds.
Now for optimum performance (tweaking the gearbox and/or the wheel diameter), you want to run the motors at peak power which is 9.36 Watts times 2 or 18.72 watts, which converts to 165.67 inch pounds per second. Moving 5 pounds times 92.25 inches and dividing by the power gives you 2.784 seconds feasible.
So you can see that for a robot less than 5 pounds, even including some inefficiencies 3 seconds is absolutely feasible.
  #128   Spotlight this post!
Unread 25-01-2011, 14:07
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Do the math. Save the world!
  #129   Spotlight this post!
Unread 25-01-2011, 14:21
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
The "little bits" here and there can kill you on the mini-bot. Our initial prototypes were 0.5 lbs heavier than we estimated (5 lbs). We had "geared" to be on peak power for those runs, but the 10% heavy also meant we needed about 10% more torque which took us down about 10% in power. Thus the 10% more weight would have added about 22% (1.1/0.9=1.21), but weight there is more... This 10% more mass also added additional friction which meant more torque, and again lower speeds therefore (1.15/0.85=1.35). Thus a mini-bot that we thought would climb in a little over 3 seconds ended up taking over 4 seconds (3.25 * 1.35 = 4.4 seconds). With certain mini-bot designs, a little weight can kill the performance for that design. This was initially very frustrating, but after review it is much more encouraging.
Back to some more iterations.
  #130   Spotlight this post!
Unread 25-01-2011, 14:25
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Check your math. The short story is -- equations only tell us where to start with MINIBOT prototyping, yet only real prototypes will tell us if the theory is sound.
The problem with such simple Power->Torque conversion in this case is that it does not account for the increased time the MINIBOT will take to get to its max speed under a higher torque load. Kinematic equations are non-linear with that respect when combined with the inverse relationship of an electric motor's speed-versus-torque relationship, thus analyzing a distance-versus-time chart between the two options may surprise you.
The problem is, distance-versus-time isn't quite as straight forward as it seems. In my analysis, I have to piecewise the graphs into acceleration sections and max-speed sections based upon the calculated time it take to accelerate to max speed under load.
So while I don't claim to have my calculations be 100% precise to real-world conditions, they do show that MINIBOTS with a 0.5:1 ratio with 4" wheels and a 5-lbs of weight will spend over 75% of their climb time in the acceleration phase, resulting in a 6+ second climb. 0.5:1 ratios with 3" wheels have 4-4.5 second climbs (50% of which is acceleration). Direct-drive 4" wheels have about the same times due to greater efficiency motor-to-pole coupled with less mass due to no gearing (all else equal), even though its max speed is technically slower than 0.5:1x3" wheels on a flat field.
...or they are direct driving but with that said you direct drive the motors get really close to stalling after only a few pounds
Actually, putting a 0.5:1 ratio on the MINIBOT puts it's torque load twice as close (ish) to stall as direct drive does.
  #131   Spotlight this post!
Unread 25-01-2011, 14:38
Originally Posted by JesseK View Post
... will spend over 75% of their climb time in the acceleration phase,
That doesn't pass the sanity check. If it takes 3-4 seconds to get to 33 inches per second, that's an acceleration of about 10 inches per second^2, or .03 g's. It doesn't start with a load of 0 g's, it starts with 1g plus acceleration, so that's about 3% reduction in available power using your numbers.
  #132   Spotlight this post!
Unread 25-01-2011, 15:27
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
... 5-lbs of weight will spend over 75% of their climb time in the acceleration phase, resulting in a 6+ second climb....
I'll ditto Gary here. Check your math on this one. I was thinking along similar lines two weeks ago and whipped up a spreadsheet to do all the numerical integration for me. The acceleration phase was stupidly short, in the tenths of a second. But we don't need a complicated spreadsheet to tell us that. If we gear for peak power, that's 1/2 stall torque. So full stall torque is 2 times the weight of the bot, is 1 g instantaneous acceleration at the beginning. When you get up to half your final speed, you're still doing 0.5g. At 3/4 final speed, it's still 1/4g, and so on.
In fact, if you toss out friction, this is a very nice linear system to model. The fact that your torque/force decreases linearly with your speed makes it just another damping term, so it actually works out to a simple mass-damper system with an external force. So if I wasn't so lazy, I could tell you the exact time constant based solely off the robot's mass and motor characteristics.
  #133   Spotlight this post!
Unread 26-01-2011, 01:03
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
...... And then... there was this
http://www.youtube.com/watch?v=sO4uNj44oZE
I'm SOOOOOOoooo envious!
Steve
  #134   Spotlight this post!
Unread 26-01-2011, 01:13
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Don't believe everything you see...all may not be as it seems. See the other related thread highlighting 1625's minibot climb. Do you clearly see the 1.5 lb. battery on the skyrocketing minibot? Do you vaguely see it?
  #135   Spotlight this post!
Unread 26-01-2011, 01:34
ttldomination's Avatar
Sunny
Right towards the end of its climb, you can see the battery fly up past the robot and fall down.
Or some other relatively heavy objected connected via wires.
- Sunny
1648: 2013-2014
5283: 2015
