Go to Post but then again, isn't FIRST a sport? I mean come on now, our championship is nothing less than the super bowl. :) - Arefin Bari [more]
Unread 23-01-2011, 18:52
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Sending basic data to driver station
Ok, so while porting our last year's labview code to java, I found that the labview version would do things like send pwm values to the driverstation.
How would I go about in doing this in java? I couldn't find anything that stuck out in the DriverStation API
Unread 24-01-2011, 16:01
Re: Sending basic data to driver station
Look at the DashboardExample Project for interfacing to the LabVIEW dashboard. You could also look into the ZomB or SmartDashboard dashboards.
Unread 25-01-2011, 13:13
DCRich DCRich is offline
FRC #2180 (Zero Gravity)
DCRich is an unknown quantity at this point
Where do you find this ZomB dashboard? --- OK, I found the reference to this.
Where is the documentation on the SmartDashboard?
Last edited by DCRich : 25-01-2011 at 13:40. Reason: Answered my question elsewhere
Unread 25-01-2011, 14:04
techplex's Avatar
techplex techplex is offline
Blake B
AKA: Blake
FRC #4909 (The Bionics)
techplex is just really nicetechplex is just really nicetechplex is just really nicetechplex is just really nice
I would just like to say that, we are experimenting with the dashboard that is already on the classmate.
We have to run the following code each loop of operator control.
float gyroValue;
        Dashboard lowDashData = DriverStation.getInstance().getDashboardPackerLow();
        lowDashData.addCluster();
            {     //analog modules
                    for (int i = 1; i <= 6; i++) {
                        lowDashData.addFloat((float) AnalogModule.getInstance(1).getAverageValue(i));
                    gyroValue = AnalogModule.getInstance(1).getAverageValue(7);
                    if (gyroValue > 360)
                            gyroValue %= 360;
                        lowDashData.addFloat((float) gyroValue);
                        lowDashData.addFloat((float) AnalogModule.getInstance(1).getAverageValue(8));
                lowDashData.finalizeCluster();
                        lowDashData.addFloat((float) AnalogModule.getInstance(2).getAverageValue(i));
                            gyroValue %= 360;
            { //digital modules
                        int module = 4;
                        lowDashData.addByte(DigitalModule.getInstance(module).getRelayForward());
                        lowDashData.addShort(DigitalModule.getInstance(module).getAllDIO());
                        lowDashData.addShort(DigitalModule.getInstance(module).getDIODirection());
                            for (int i = 1; i <= 10; i++) {
                                lowDashData.addByte((byte) DigitalModule.getInstance(module).getPWM(i));
                        int module = 6;
                        lowDashData.addByte(DigitalModule.getInstance(module).getRelayReverse());
            lowDashData.addByte(Solenoid.getAll());
        lowDashData.commit();
Best,
Blake
Electrical, Programming and Design
Creator FRC Q&A 2017
Mass FRC Team 4909: The Bionics
Maine FRC Team 5122: The RobOTies (2014-2015)
Maine FRC Team 2648: Infinite Loop (2008-2011)
Unread 25-01-2011, 15:14
wdell wdell is offline
AKA: William Dell
FRC #3999 (Shadetree Mechanics)
wdell has a spectacular aura aboutwdell has a spectacular aura about
I posted a java class here that will handle basic communications with the driver station and dashboard. While I'm sure it could be more sophisticated, it does work (at least so far ). I'll try to update things as I sort more of the code out.
Unread 25-01-2011, 22:04
AKA: William Dell
I posted a class here that I'm using to handle communications with the driver station and dashboard. I'm sure it if feature incomplete, but at the moment it does a good job of interfacing with both station and dash, and simplifies communications with the station LCD. If you find it useful, enjoy, just toss a blurb in there giving me and Team 647 some credit, and if you improve it let me know
Unread 27-01-2011, 14:35
AKA: Brad
#0190 ( Gompei and the Herd)
The SmartDashboard and ZomB dashboard are both projects on firstforge.wpi.edu. You don't need an account to access either of them, and the source code is included with both distributions.
Brad Miller
Robotics Resource Center
