Go to Post Please ask yourself..."If my robot is on fire and the pneumatics are randomly activating, is my main breaker someplace that I want to put MY hand?" - Jaxom [more]
Unread 25-01-2011, 16:58
Paul Rodi Paul Rodi is offline
FRC #0975
Paul Rodi is an unknown quantity at this point
Re: Rookie team: How do we set up our cRIO?
We already have that, and it hasn't worked.
Is there a version of that for Windows 7?
Thanks anyway
Paul Rodi
405, 346, 975 Alumni
President Emeritus of FIRST @ VCU
Coach 975, 1033, 1102, 1541 and whoever else
Unread 25-01-2011, 17:02
plnyyanks's Avatar
plnyyanks plnyyanks is online now
Data wins arguments.
AKA: Phil Lopreiato
Thanks anyway
the cRIO imaging tool should work with Win 7 (it worked with my laptop running 7). To get to the network adapter configuration, click on start, type in "network and sharing center" and click on it, click "change adapter settings" on the left panel, right click on Local Area Connection and select properties, and set the static IP as per the document.
Unread 25-01-2011, 22:57
What step doesn't work? What happens instead of what you expect? Be as specific as you can so we can give you useful advice on what to do next.
