Go to Post The robots are the attracting force, the common interest that brings us all together - sanddrag [more]
Unread 25-01-2011, 10:30
jhellr13 jhellr13 is offline
FRC #4272
jhellr13 is an unknown quantity at this point
Labview Help
I have successfully downloaded Labview from the KOP on to the classmate.
I am trying to use that same disc to install Labview on my home desktop for programming purposes. For some reason, the serial number from the KOP won't work on this computer, even though this Labview version should work across multiple computers.
Please Help!
Unread 25-01-2011, 15:27
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: Labview Help
have you been able to successfully install labview (and just not activate it)? you can try installing it without a serial number in evaluation mode (works for 30 days) and then try to activate it.
Unread 25-01-2011, 18:21
FRC #4272
Re: Labview Help
Yes, I have tried that, but i want to activate it so i can use it past the standard 30 days. I can't figure it out
Unread 25-01-2011, 18:51
plnyyanks's Avatar
AKA: Phil Lopreiato
Re: Labview Help
what I was trying to get at was weather or not your problem was with the LabVIEW install process or activation process.
Unread 25-01-2011, 19:17
Team#2057-Vegas's Avatar
Team#2057-Vegas Team#2057-Vegas is offline
Team2057LasVegas
AKA: Justin Major
FRC #2057 (AV CyberBulls)
Team#2057-Vegas can only hope to improve
Re: Labview Help
contact a NI representative. it should work on multiple computers.. I know our team has it on 5 or 6 right now.
Justin Major
2057 Team Leader
"We will kick you off our pasture" -- 2057 Motto
Unread 25-01-2011, 21:12
FRC #4272
Re: Labview Help
My problem is with the activation part. I am trying it again as i am typing right now, so i will see what happens. If it doesn't work, then i will probably contact NI.
