Go to Post When it all comes down to it, it's not gonna be the medal around your neck that makes the difference, but the memories that you think about when you look back on how you got there that makes the difference. - Beth Sweet [more]
Unread 25-01-2011, 16:54
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
update issues
I tried to update NetBeans for the first time since mid-December (since our laptop at robotics club doesn't have wireless, I have to connect via ethernet in another classroom to get the Internet), but it seems like NetBeans is refusing to recognize that I did. First I let NetBeans do the automatic update of the FRC plugins, and it seemed to work. Then when I tried to download and run my code on the robot I got this message:
C:\Documents and Settings\Administrator\sunspotfrcsdk\build.xml:95: The following error occurred while executing this line:
C:\Documents and Settings\Administrator\sunspotfrcsdk\ant\upgrade.x ml:40: Expected version FRC_2011_v25.zip; for Name but got FRC_2010_v20.zip;. Go to http://first.wpi.edu/FRC/frcjava.html to get latest software update
BUILD FAILED (total time: 10 seconds)
So I downloaded the update from FIRST Forge (http://firstforge.wpi.edu/sf/frs/do/...cts.wpilib/frs) directly and tried to install the modules, but when I did it said they were already installed. So then I tried uninstalling the previous updates and then installing the files I downloaded, and that worked. I tried to download again and got the same error. Next I tried to see if FRC_2011_v25.zip was somewhere on my computer, and I found it where it's supposed to be (C:\Documents and Settings\<user name>\sunspotfrcsdk\cRIO_Images). It was the only zip file in that folder. I did however find FRC_2010_v20.zip in C:\Program Files\National Instruments\LabVIEW 8.6\project\CRIO Tool\FRC Images
Can anyone help?
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
Unread 25-01-2011, 18:57
Re: update issues
You need to install the Utilities Update from the software update page and then reimage the cRIO with the v25 image.
