Go to Post Same as regrets in life: Learn from them. This is called "growth". - DonRotolo [more]
Unread 25-01-2011, 19:25
carfreak3504 carfreak3504 is offline
FRC #1510
carfreak3504 is an unknown quantity at this point
Mounting Pneumatic Parts
I need to know how to mount these parts:
One assembly includes an emergency relief valve, electronic automatic relief valve, and a gauge. All connected using 2 T's and 2 1/8-1/8 connectors
The second is a regulator with 2 T's on each side, connected with 1/8-1/8 connectors.
I would prefer NOT using zip ties. Any suggestions?
Thanks
Unread 25-01-2011, 19:46
earlybird's Avatar
earlybird earlybird is offline
They tried to ship me 2 competition
AKA: Robbie Oehrli
FRC #2849 (Team Ursa Major)
earlybird is a jewel in the roughearlybird is a jewel in the roughearlybird is a jewel in the rough
Re: Mounting Pneumatic Parts
You might be able to drill a hole in your frame, where you want to mount them, so that you can screw two of the pieces together in each assembly, one on each side of the hole. That way when you screw them together they should hold them selves in place. That might work, but my team has always used zip ties in the past.
Unread 25-01-2011, 22:34
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
What's wrong with zip ties?
If it's for aesthetic reasons, I would suggest attaching straps of the desired color and material to the frame with blind rivets wherever zip-ties would otherwise be used.
Unread 26-01-2011, 15:26
Michael William Michael William is offline
AKA: Captain
FRC #1510
Michael William is an unknown quantity at this point
Here is a picture showing the two assemblies we need to mount. I believe we have a bracket that attaches to the regulator shown on the left; it's the PSI gauge, sensor and relief valve on the right that I'm more concerned with. Our team likes to not design using zip-ties, just a preference. The strap may work, but I would be concerned that the assembly would bang around during a match. Anyone else have any ideas to mount these rigidly? Ideally, the gauge and relief valve knob would be pointed up for easy access...
Name:	Regulator_guage_sensor_valve photo.JPG
Unread 26-01-2011, 15:45
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
We've often used cable clamps to tie pneumatics to the frame. Examples are nylon ones such as this or metal/rubber ones like this.
Unread 26-01-2011, 15:54
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
We try to minimize the number of brass parts we use as much as possible (in favor of push-to-connect fittings) to reduce weight. We usually only use a single brass tee, and use that to mount the high-pressure gauge right next to the regulated gauge. The pressure switch goes into one of the accumulator ends. Somewhere on the high pressure side we use a push to connect tee, and mount the manual vent valve right next to the main breaker.
We also mount everything with zip ties, as this photo from our unfinished 2007 robot shows.
Art Dutra IV
世上无难事,只怕有心人.
Unread 26-01-2011, 16:37
R3P0's Avatar
R3P0 R3P0 is offline
Always InTeNsE!
AKA: Jamie Robinson
FRC #1504 (Desperate Penguins)
R3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of light
Send a message via ICQ to R3P0 Send a message via AIM to R3P0 Send a message via Yahoo to R3P0
IF you are going for that steamphunk kinda look go with these--> http://www.boltdepot.com/u-bolts.aspx?wt.srch=1 obviously you have lots of weight to add these
Time is irrelevant at the speed of light.
