Go to Post this is ridiculous, a complete waste of time, and probably not particularly effective. I love it! - The other Gabe [more]
Unread 23-01-2011, 19:32
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
programming KOP line trackers
can any one please explain to me how to program the KOP line tracker in c++, or explain in full detail the example code which confused me alot. I do know that They are digital inputs, but im wondering if you have to use a specific ".h" in the file wpilib. to declare a line tracker variable, or DigitalInput, and what kind of data does it read and how to test it if it is working whether by using "printf" which never seems to print anything to the driverstation or something else. It is the first time my team is using one.
-thanks in advance
Unread 25-01-2011, 02:29
CodeMonkeyMatt CodeMonkeyMatt is offline
FRC #2605
CodeMonkeyMatt is on a distinguished road
Re: programming KOP line trackers
I haven't looked into the line trackers, so I can't help you there, but I can help on the printf statement. It prints not to the driverstation, but to the target console. Normally, you won't see this. To pull it up, go into windriver while connected to the robot, right click the VxWorks connection in the bottom left, and go to "Target Tools" -> "Target Console"*.
*May not be perfect. I don't have windriver on this computer.
Unread 25-01-2011, 11:18
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
thanks man i have been looking all over for the target console, but one question, is there any way to slow down the way the target console reads the values?
Unread 25-01-2011, 11:49
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Nope, they're just default DigitalInputs. You can use .Get() to get its status - 1 is tripped, 0 is not tripped. On carpet, though, you'll have to do !sensor.Get(), because carpet's dark and the lines are light.
GSR Dean's List Finalist 2011
Unread 25-01-2011, 21:17
FRC #2605
Well, you could set up a counter so it only prints every tenth value it reads, or every hundredth or whatever.
Unread 26-01-2011, 20:00
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
How do i do that?
Unread 26-01-2011, 22:05
FRC #2605
Something along the lines of this:
int count = 0;
while(IsOperatorControl())
   readInput(); //However you get the data
   count++;
   if(count >= 10)
      count = 0;
      printData();
Unread 26-01-2011, 22:45
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
To elaborate on what Demosthenes2k8 said, The values you get are dependent on a couple things. First, the sensor has two outputs, one is normally high, while the other is normally low. Depending on which wire you hooked up to your Digital Sidecar will affect what you read in the code. Also, the sensors have an adjustment knob on them. The sensors will most likely have to be calibrated to work on what ever test surface you are using. Just make sure it has a good contrast.
