Re: Camera Code
I kind of think the spirit of FIRST ethically compels me to share my code, if it will help someone else. That being said, I'm a teacher, so if it can help someone learn I'll share it with them.
I use multiple classes to break the code down into reusable pieces, and spin off threads to allow things like the driver station to take care of themselves. I use a separate class to define autonomous routines (go straight, turn left, turn right, back up, etc.), and then call those methods in autonomous() in a script like fashion, i.e. Code:
public void autonomous() {
autodrive.goStraight(8); // go straight ahead for 8 seconds
autodrive.turnRight(90); // turn right 90 degrees
autodrive.backUp(3); // back up for 3 seconds
The whole thing is modular that way. I use SimpleRobot instead of Iterative: it allows finer control of a multi-threaded model, without the interference of the automatic looping in Iterative. Iterative would eliminate threads, but would also be more monolithic, and therefore less reusable. Off topic I'm sketching out my camera class, so I'm looking for better (meaning easier to follow) code than the stock examples. Jimmy's looks good, and I can actually read it (well, mostly ) |
Re: Camera Code
Also thank you for joining the initiative. Autonomous has been lacking in FIRST teams, so I agree it is the responsibility of successful teams to lead the endeavorer and stay open source |
Re: Camera Code
647 has essentially had NO autonomous capability in the past, so for now series will work. A decision tree is a great idea though, I'll definitely take a look and see what I can implement in the future.
Re: Camera Code
I found in the past that the camera processing is unneccessary. A lot of times it is just easier to use delays, especially since the example camera code is so hard to follow, but that is because they added things that were unnecessary. I think if we can get very simple camera code that anyone can follow and modify, more teams will use the camera in auton.
