Go to Post I've never been one for the "you did your best" and other "everyone's a winner" sayings, they don't push you, they don't get you to analyze what went wrong and figure out where to improve. - Aren_Hill [more]
Unread 25-01-2011, 22:02
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: Team Update #5
Originally Posted by Chris is me View Post
Wow, I missed the minibot part completely - that's quite nice.
Anyone got a recommendation for a 2 amp fuse?
Let's see if I am thinking what you are thinking.
You use all the power the motors give you, climp up the pole, hit the top burn out the fuse and replace after match and redo next match and so forth?
Cheaper and easier to replace a blown fuse then to have another switch on the bot to bring it back down. The issue I have of placing a switch on the bot to bring it back down the pole is, what if that switch trips or something, then you will not reach the top that match.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 25-01-2011, 22:12
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Re: Team Update #5
The BEST part of this entire update for everyone is
DD. Non-functional decorations.
174 1/2 can finally get pimped out now.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 25-01-2011, 22:23
rocketeer1 rocketeer1 is offline
FRC #2993
rocketeer1 is an unknown quantity at this point
Re: Team Update #5
Hey, thats a good idea. Thanks.
Unread 25-01-2011, 22:38
pfreivald's Avatar
AKA: Patrick Freivald
Re: Team Update #5
I was thinking the same thing...
...but we have to be careful that the fuse fries before the motors do, don't we?
That said, playing around with the MINIBOT (and not having yet found that super-optimal gearing), we have found that even somewhat significant weight changes (.5 lbs or so) seem to have almost no effect on the climb rate...
This might well change when we find that 'optimal gearing', of course.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 25-01-2011, 23:18
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: Team Update #5
You have an upper frame. It is the same size as the frame in the area of the Frame Perimeter. You have one bolt that sticks out over the frame perimeter.
Previously, you would not have been allowed to compete. Now, you are. It's the same change they made last year in like Week 4 or 5 of build, IIRC.
Wouldn't it still not pass initial inspection during the box test? Or is that what they are altering?
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 25-01-2011, 23:22
Re: Team Update #5
Nope, because the smart teams always build smaller than the box to allow for bolt heads. Bolt heads are exempted from the frame perimeter. So it's quite possible to have a bolt head sticking out from the volume defined by the frame perimeter (vertical dimension infinite). Before this ruling, that would have been an issue--it was last year. Now that this update has come out, there is much rejoicing that this doesn't have to happen again.
The box is still the box; no leniency on that for being oversize.
Unread 26-01-2011, 01:39
Molten's Avatar
AKA: Jason
Re: Team Update #5
That's good. I thought FIRST was starting to go easy. Who knows maybe the next update would have been "its ok if your .5 lbs overweight?". Now that I understand the difference, an overall good ruling.
Unread 26-01-2011, 01:45
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Re: Team Update #5
Team222badbrad remembers when nobody knew what bumpers where...
"<R14> When a ROBOT is in its STARTING CONFIGURATION, no part of the ROBOT shall extend outside the vertical projection of the FRAME PERIMETER"
Now we don't have to worry about adding lexan and such to our frame to make the bolts flush...
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 26-01-2011, 08:48
Re: Team Update #5
Please also note that the update is allowing the thermal protection wires for the Tetrix motors as listed on the linked Approved Tetrix Parts list.
R92..
A. TETRIX components that are not in violation of any other rules (Tetrix components are listed in Approved Tetrix Parts at www.usfirst.org/frc/competitionmanual),
Unread 26-01-2011, 10:16
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Team Update #5
Woohoo, we can solder the motor leads so they don't come unplugged! There would be many disappointed MINIBOT deployers if they didn't allow this. It was fairly painful in 2009-2010's FTC game.
Unread 26-01-2011, 10:59
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Team Update #5
I'm excited because our base is 1" undersized in any direction, but we have some minor protrusions in the bumper zone, and possibly one or two above, and they weren't specifically addressed prior to this update. I can sleep again.
Oh, and I can get rid of the wooden shims.
-Dustin Benedict
Unread 26-01-2011, 11:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Team Update #5
Why would you ever want to add useless mass to the minibot?
EDIT: I guess some identifying markings wouldn't weigh much.
Unread 26-01-2011, 11:38
Tetraman's Avatar
FIRST on my mind
AKA: Evan Raitt
Re: Team Update #5
Yea. A splash of color and team number would be all that is necessary. Having a black box felt so boring.
Unread 26-01-2011, 11:40
JesseK's Avatar
FRC #1885 (ILITE)
Re: Team Update #5
Additionally, it allows us to powder coat the MINIBOT parts that do not contribute to motion or friction (i.e. anything that doesn't directly make contact with the pole).
Unread 26-01-2011, 13:20
PaW's Avatar
PaW PaW is offline
AKA: Paul W
FRC #1899 (Saints Robotics)
PaW has a spectacular aura aboutPaW has a spectacular aura about
Re: Team Update #5
Sponsor's logos!
