Go to Post For the love of God,please post the hint. We're starting to lose control. - johnr [more]
Unread 25-01-2011, 15:33
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
For all who want to mess around with mecanum
Read this pdf: http://www.chiefdelphi.com/forums/at...9&d=1295551765
IT ANSWERS EVERYTHING YOU NEED TO KNOW WHEN USING C++, JAVA, AND PYTHON
Unread 26-01-2011, 00:25
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: For all who want to mess around with mecanum
That's not everything they need to know, that's how to program them. Aren't there libraries that even do that for you? There are in labview, at least.
There's no mention of weight distribution, diamond vs X configuration, chain or direct drive, how to manufacture them/put together the anymark kit, what kind of motors to use, or even things like how to vary motor speed or square/cube the inputs.
Unread 26-01-2011, 00:36
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
That part is the easy part. IMHO the hard part is actually affording one.
Unread 26-01-2011, 15:02
Redneck's Avatar
Redneck Redneck is offline
Hacker Hick
AKA: Jamie (2.0) Moran
FRC #0599 (Robodox)
Redneck is just really niceRedneck is just really niceRedneck is just really niceRedneck is just really nice
Send a message via AIM to Redneck
Thank you, thank you, thank you! This'll be perfect for introducing our new programmers to mecanum drive code. Not much detail about the math behind it, but that'll be easy to explain with this as a nice reference for the end result.
Which badges can you claim?
Unread 26-01-2011, 15:28
Please use the link to the most recent revision. It's located here, at the very bottom of the list.
If you want "detailed math" for teaching purposes, there's a detailed kinematic analysis and force analysis at the same link. They're the first and third papers from the top of the list.
