Go to Post Half your robot could be broken, some drive chains snapped, a drive motor burned out, etc... and your WCD will still be trucking. - AdamHeard [more]
Unread 26-01-2011, 05:54
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Mounting a BB 775 to a P60
Hi,
I was wondering if any special tools are needed to connect a BB775 motor to a P60 gearbox.
we are ordering the one with the mounting kit for the 775:
http://banebots.com/c/P60K-S7
what is the mounting procedure?
is it reversible? (if we fry a motor, can we easily remove the mountings from the fried motor and transfer them to a non-fried motor?)
Thanks,
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 26-01-2011, 12:33
Bernoulli Bernoulli is offline
Bernoulli is an unknown quantity at this point
Re: Mounting a BB 775 to a P60
all you are gonna need is the mounting screws because there both made to fit flush together and for how easy it is depends on the set up because you still have to pull the motor-transmision combo off the hub because the mounting bolts on on front of bane bot transmision
Unread 26-01-2011, 17:19
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
The motor shaft is smooth... how do you add a gear on there?
is it a press fit? do you need a press or can you use a bench vice?
-Paraphrasing JFK
Unread 26-01-2011, 18:59
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
The gear does need to be press fitted on. I'd recommend an arbor press, and I'd use a large milling vice if I didn't have an arbor press. I wouldn't use a bench vice. If I had a large robust lathe, I'd attempt pressing it with the tailstock if I didn't have anything of the aforementioned tools.
In a real pinch, I suppose you could whip together some sort of frame for an automotive bottle jack, and then you'd have a press of sorts.
Unread 27-01-2011, 16:48
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I don't have a hard time imagining that some teams are without access to an arbor press, a milling vice, a large lathe, or a bottle jack (and even those teams that could get/have a bottle jack might not have the time or materials to build a frame for it). Would it really be that bad with a bench vise or a really big C-clamp?
Unread 27-01-2011, 17:18
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The problem with a bench vise, and especially a C-Clamp, is the slop and play in the clamping surfaces. Too much slop makes it easy for the shaft or gear to get out of alignment. This just encourages the application of more force, which can pretty quickly result in a bent shaft.
Since it hasn't been mentioned, you need to make sure you're pushing only against the back part of the shaft when you press this on. If you set it up so you're pushing against any other part of the motor, you're going to destroy bearings, the motor frame, etc.
