Go to Post The people that have posted in this thread are intelligent and I know that when they talk, I need to listen. - ATannahill [more]
Unread 26-01-2011, 05:21
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
WPA Key?
We need a WPA Key to configure the D-Link. What is that WPA Key?
Unread 26-01-2011, 06:42
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: WPA Key?
The key can be whatever you want as long as it is programmed on both the classmate end and the robot bridge. FIRST recommend using <team number>WPAKEY. So for my team, 3096, we would use 3096WPAKEY.
FIRST details how to set the up in thier "How to Configure Your Radio" document at http://www.usfirst.org/uploadedFiles...Your_Radio.pdf
In reality, I had a hard time getting the encryption set-up and for shop use I skipped it am running un-encrypted. You bridge will be encrypted by the event staff at your competitions. You will have to take it back off when you get back to the shop to use the robot there.
Hope this helps.
Mark
Brick walls are for other people. - Randy Pausch
Unread 26-01-2011, 06:52
FRC #2905
Question Re: WPA Key?
We did what you ve told us but in the network settings when we change "IP Address" and the other stuff like in the manual and save it we see an error on the screen. I dont really understand why is that happening?
Unread 26-01-2011, 06:54
kramarczyk's Avatar
Re: WPA Key?
A picture or description of the error would go a long way towards diagnosing the problem.
Mark
Unread 26-01-2011, 07:24
FRC #2905
When I click on save what I dont understand after a while the page directs to log out.And after that it gives the error and it says the page you are looking for cannot be displayed.
Unread 26-01-2011, 07:40
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: WPA Key?
That is normal after you change the IP address. Your computer still has a 192.x.y.51 address, the D-LINK has a 10.x.y.4 address, so they don't talk to each other... yet.
Continue on with the next step which should be changing your computer's IP address to 10.x.y.51, switch the d-link to AP mode and type the IP address of the dlink into your browser.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 26-01-2011, 07:41
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Re: WPA Key?
This is because you changed the IP of the bridge, so it doesn't match the IP of your computer anymore - therefore, they can't communicate.
As soon as this error page shows up, change your computer's IP address to the IP address you just set the bridge to, then reload the page. You should be able to see it then.
Speaking of this, I was not very happy with the documentation this year. There are large gaps in the documentation from a system standpoint. For example, it's great that it tells you how to set up the bridge, but there is no documentation explaining how to set up the driver's station computer to talk to the bridge.
Unread 26-01-2011, 08:45
Re: WPA Key?
There's a distinct lack of "why", but the "what" and "how" seem quite complete to me.
That's probably because you're not intended to use the Driver Station to talk to the bridge.
Team Update #5 hints at a new radio setup document, but I didn't see it there.
Unread 26-01-2011, 08:58
Re: WPA Key?
The How to Setup Your Radio document is terrible.
Short but terrible.
It has all the right information, but jumbled in the wrong order.
It starts with a procedure for competition that I find it hard to believe we will ever use, but maybe I'll just be disappointed to be back on the 2009 WEP help desk.
It misleads people into thinking you need encryption at home, but doesn't give directions for that.
Unread 26-01-2011, 09:58
FRC #2905
Re: WPA Key?
Thanks for your helps I have done the configuration of the radio.
Unread 26-01-2011, 10:07
Re: WPA Key?
It's up now.
Unread 26-01-2011, 10:19
Re: WPA Key?
If the driver station doesn't talk to the bridge, then how does the robot get the joystick commands? Somewhere along the way the data from the driver station needs to get to the robot (and vice versa).
Unread 26-01-2011, 10:50
Re: WPA Key?
When not at a competition event, the Driver Station connects wirelessly to the DAP-1522 router in Access Point mode. I would have expected you to know that already, and I am not sure why you asked.
When at a competition event, the Driver Station connects to the field system using a wired Ethernet cable. The DAP-1522 connects wirelessly to the field network in Bridge mode.
The Driver Station "talks to the bridge" by going through the virtual network provided by the field system, but it never knows anything explicitly about the bridge.
Unread 26-01-2011, 11:38
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: WPA Key?
I'm pretty sure Chris was asking a rhetorical question. It was the question of the Driver Station talking to the bridge or the Driver Station talking to the Bridge in Access Point mode.
Short but terrible.
I completely agree. The new Radio Configuration document helps a little for some teams I'm sure but it needs a lot of work. I don't know why they did it this way compared to last year's documentation, which was pretty awesome really.
Unread 26-01-2011, 11:45
Re: WPA Key?
Yes, what David said.
My point is this: when our students set up the radio as explained in the document, our driver station would not communicate with the robot (either in bridge mode OR access point mode). There are a number of missing steps in the documentation that were needed to get it to communicate.
