Go to Post It's just another design constraint that needs to be dealt with. - Dave Scheck [more]
Unread 13-01-2011, 12:53
Maxbotix Maxbotix is offline
Junior Member
Maxbotix is just really niceMaxbotix is just really niceMaxbotix is just really niceMaxbotix is just really niceMaxbotix is just really nice
MaxSonar Ultrasonic Pole/Tower Sensing & Detection Application Note!
MaxBotix Inc., had completed an application note that may help teams use the MaxSonar ultrasonics sensors in the 2011 FIRST competition. This note covers using the sensors for pole detection, distance, and direction to align the minibot for placement on the pole.
Please click this link to view the web page with the application note http://www.maxbotix.com/MaxBotix_Robot_Sensors.html.
In addition, we have applications notes listed on the webpage above on how to run more than one MaxSonar sensor at a time.
We wished each FIRST team the best of luck with their bot!
If you have any questions, please email me at scott@maxbotix.com.
Best regards,
Scott Wielenberg
Technical Support & Sales
of MaxBotix Inc.
Phone: (218) 454-0766 Ext. 2
Fax: (218) 454-0768
Email: scott@maxbotix.com
Web: www.maxbotix.com
Unread 26-01-2011, 04:35
calica calica is offline
FRC #2471
calica is an unknown quantity at this point
Re: MaxSonar Ultrasonic Pole/Tower Sensing & Detection Application Note!
Anyone know how to put a DIO into the HighZ state? We're using Java.
Thanks.
Unread 26-01-2011, 08:40
Configure it as an input. However, the DIO pins all have 10k pullup resistors on them. How high an impedance do you want?
Unread 26-01-2011, 15:44
Junior Member
Thanks for the question. A 10K resister will work fine. Please let me know if you have any other questions.
Best regards,
Scott Wielenberg
of MaxBotix Inc.
Fax: (218) 454-0768
Unread 31-01-2011, 17:24
FRC #2471
You need to set it as a output to send the initial pulse. Then as an input to let the pulse "loop back around" from the last MaxSonar.
I was a little worried about Java not GC'ing the DigitalOutput object fast enough. But it looks like using DigitalModule.*DIO() should allow the control needed.
Unread 31-01-2011, 18:47
Besides the programing language time, the NI 9403 can have up to an 18 us delay in switching directions.
Unread 13-02-2011, 16:43
computerish computerish is offline
FRC #0619
computerish is an unknown quantity at this point
Has anyone actually gotten these working with the daisy chaining? We wired up two LV-MaxSonar-EZ4s for daisy chaining and we can get it working on a breadboard.
Unfortunately, we can't figure out how to reconfigure a digital i/o pin as an input once it is configured as an output. We are getting an AllocateException. We are using Java. Any ideas?
Unread 13-02-2011, 16:58
FRC #0619
We found the solution:
DigitalModule dm = DigitalModule.getInstance();
dm.freeDIO(pin number);
Unread 25-02-2011, 10:35
Team0865 Team0865 is offline
FRC #0865
Team0865 is an unknown quantity at this point
Will using an XL-MaxSonar-EZ0 work just as well as XL-MaxSonar-EZ0? I've looked at the schematic for the daisy chain and I was wondering where each of the wires get wired back to on the digital side car. Our team has limited electronic experience so any additional help would be great.
Thanks,
Team 0865
Unread 25-02-2011, 11:13
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
We use the MaxSonar modules in the analog mode. They return a value every 99 ms and work very well for us.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
