Go to Post ...when the rack starts swaying you start praying! - Wayne C. [more]
Unread 26-01-2011, 09:05
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
FRC #1860 (Cephatron)
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
Can we build our own wheel to Minibot?
Hi,
We have a doubt.
In according with <R92> only Tetrix components are permitted.
In this list: http://www.usfirst.org/uploadedFiles...ix%20Parts.pdf is showed two differents wheel's models.
The question: We must to use these specifics wheels or can we build our own wheels respecting the materials rules associated at <R92> rules.
For example: A Polycarbonate wheel with any non-slip pad around it?
Thanks in advance
Unread 26-01-2011, 09:07
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Can we build our own wheel to Minibot?
There are no rules prohibiting this practice and I expect to see many teams do it.
Unread 26-01-2011, 09:10
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rule <R92> does not restrict the Minibot to only Tetrix parts, it restricts the Minibot to only parts listed in <R92>. If your wheel is constructed completely of parts listed in that rule it should be legal.
A polycarbonate wheel with non-slip pad or split surgical tubing as the tread should be perfectly legal as each of those parts is listed in <R92> as an allowed part.
EDIT: Brandon, see <R92-P>
Unread 26-01-2011, 11:06
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Just be careful about exactly what you build it out of and how. The GDC seems to interpreting this section very strictly, so make sure you use polycarbonate and not acrylic. Or if you're making wheels out of aluminum, make sure your raw stock was sold as "bar", "sheet", or "tube". Yes, this probably complicates machining by preventing the use of aluminum rod or discs, but that's the way the cookie crumbles.
