#8
Re: Modular connector between motor and Victor?
Anderson modular connectors
housings McMaster P/N 8026K52 Housing for 15, 30, & 45 Amp, Black Modular Connector, Packs of 5 (Same as 8026K5) 8026K51 Housing for 15, 30 and 45 Amp, Red Modular Connector, Packs of 5 (Same as 8026K5) connector pins for housings above, the different pins accomodate different wire sizes, all pins fit in the above housings McMaster P/N 8026K95 Modular Connector Contact, 45 Amps @ 600 VAC/VDC, Packs of 5 8026K91 Modular Connector Contact, 30 Amps @ 600 VAC/VDC, Packs of 5 8026K96 Modular Connector Contact, 15 Amps @ 600 VAC/VDC, Packs of 5 |
