Go to Post The robot uprising has begun. - SpoonMechanic [more]
Unread 26-01-2011, 10:12
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
Re: HS-322HD and Digital Sidecar PWM output
Originally Posted by sjspry View Post
<snip>
The motor jumps when first plugged in, but otherwise nothing seems to happen. When I don't set the "period multiplier" that PWM.java makes note of, the motor does not hum and/or heat up. So I'm assuming the signal is not working correctly, but perhaps it's something else.
As far as I can tell everything is plugged in correctly, and I'm using PWM.setRaw() and scrolling from 0-255 in increments of 5 with a delay of about half a second.
So, help?
I am assuming the servo is not connected to anything (mechanically) and therefore not stalling.
Have you tried not setting the period and using set rather than set raw?
I have two servos running using the 'set', so there isn't anything broken there (library-wise) that I have seen, but I am not at the robot and can't look at the raw commands until later. If I haven't seen a resolution by then I'll try them this afternoon.
