Go to Post I even liked the Bieber commercial. - Andy Baker [more]
Unread 26-01-2011, 10:47
wdell wdell is offline
AKA: William Dell
FRC #3999 (Shadetree Mechanics)
wdell has a spectacular aura aboutwdell has a spectacular aura about
Re: Driverstation / Dashboard in JAVA
Originally Posted by frasnow View Post
You must have 2011.3. Don't install the plugin update to 2011.4, or that line of code will break. I've looked at multiple systems.
No, I am using 2011.4. No errors, builds and loads fine.
As for the curt answer, I was going back to check and see if I could reproduce your problem, which I cannot. I have no errors and no warnings on that line, or any other line in that class. I deployed this to my test bot last night and it worked fine.
Unread 26-01-2011, 11:23
AKA: William Dell
Updated the DStation class above with a cleaned up, and hopefully better commented copy. I still need to flesh out exactly what the updateDashboard method is doing, but I think I've got a handle on it now, including how to extend it. Maybe
Unread 26-01-2011, 13:38
AKA: William Dell
Confirmed. I just finished running my test rig up and down the school hall (noon CST), and the DStation code performed as expected. Sorry frasnow, I'm not sure why it's not working for you, but no problems here.
Unread 26-01-2011, 22:02
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
I just started making my own Dashboard in Java and am skipping the protocol they designed entirely (and having the cRIO send stuff with SocketConnection). To be honest, the current system is too much of a pain to consider using.
Unread 26-01-2011, 22:21
frasnow's Avatar
frasnow frasnow is offline
Software
frasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to behold
It's so strange that 2011.4 works on your system, but none of the 4 systems I've tried.
Today I tried this:
1. Uninstalled all the FRC plugins from Netbeans.
2. Installed what is called version 4.8 on FIRST forge (version 2011.3). With this configuration Solenoid.getAll() is fine and is even declared Static as it should be.
3. Uninstalled version 4.8 from FIRST forge and downloaded & installed version 4.9 (version 2011.4). I get the Solenoid.getAll() is non-static error. Looking in the code, it is indeed not declared as static.
All my other systems are using the automatic updates. I just can't understand how your 2011.4 is different from the one on all my systems. It's not an OS problem; I've used Windows 7, Windows XP, Mac OSX, and Linux. It's not a Netbeans version problem; I've tried 6.7, 6.8 and 6.9.1.
Unread 27-01-2011, 08:53
AKA: William Dell
hmm. I'm using Netbeans 7.0 beta, but that shouldn't make any kind of difference.
You could try replacing the solenoid line with:
byte thisBytes = 0;
lowDashData.addByte(thisBytes);
Basically forcing the solenoids to always be zeroed.
Unread 27-01-2011, 08:55
AKA: William Dell
I've just checked using Eclipse, and the error you have is showing up there. I have no idea why it works when I use Netbeans. I may have to actually hunt down where the libraries are stored on my disk and physically delete them, then re-update.
Unread 27-01-2011, 09:45
frasnow's Avatar
Software
Wow! I really appreciate your tenacity in trying to reproduce my problem. Hopefully FIRST will fix it soon. I was so astounded by them breaking the example code that I tried to send a message to Derek White at Oracle. He's listed on FIRST Forge as one of the project administrators.
I'm having my students try the 0 byte thing tonight, since I won't be there to mentor them. Have you already confirmed it works? My other idea is to waste one of the solenoid connections in order to get an instance variable to call the non-static getAll(), which should allow it to display the state of the solenoids.
Unread 27-01-2011, 10:06
It's in the wpilib tracker http://firstforge.wpi.edu/sf/go/artf1322
Unread 27-01-2011, 10:13
AKA: William Dell
I completely eradicated Netbeans from my computer and reinstalled... twice. Found the problem. Whatever is going on, even though my machine was claiming it had 2011.4 installed it hadn't actually updated the libraries. Got it sussed now, and yes, that line is broken.
Haven't had a chance to test the 0 byte workaround, won't be near my lab for a couple hours yet.
Unread 27-01-2011, 12:13
frasnow's Avatar
Software
Thanks Joe!
Unread 27-01-2011, 13:52
AKA: William Dell
The zero byte workaround is good. You don't get a reading for the Solenoids on the dashboard, but you don't get error messages either.
Unread 27-01-2011, 18:00
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
With version 2011.4 I observed that the posted dashboard code does not properly map the digital i/o pins on the sidecar to the leds on the dashboard gpio state and gpio output enable. First two leds are always off and led 3 maps to digital i/o 14. i/o 1 and 2 do not change any led on the dashboard.
The following code works properly:
                        int dioData = 0;
                        for( int i = 1; i <= 14; i++)
                            if( DigitalModule.getInstance( module ).getDIO( i ) )
                                dioData |= ( 1 << i-1 );
                        lowDashData.addShort((short)dioData);
                        int dioDir = 0;
                            if( DigitalModule.getInstance( module ).getDIODirection( i ) )
                                dioDir |= ( 1 << i-1 );
                        lowDashData.addShort((short)dioDir);
There seems to be a problem with getAllDIO() and getDIODirection().
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Unread 28-01-2011, 19:00
TPNigl TPNigl is offline
FRC #0069 (Team HYPER)
TPNigl is an unknown quantity at this point
We are getting the problem that it is looking for v_20 and we already updated to v_25. We tried the above code and everything worked except the version error. Any ideas?
2011 Pit Crew:
2011 CT Xerox Creativity Award
HYPER Alumni
Unread 29-01-2011, 12:07
DCRich DCRich is offline
FRC #2180 (Zero Gravity)
DCRich is an unknown quantity at this point
We rev'd back to 2011.3 and the dashboard is now working!
Ughh how much time we have wasted :-(
