Go to Post I personally need all the limbs and eyeballs I currently have, and I assume other feel the same way. - bfk [more]
Unread 24-01-2011, 20:13
toddthetoad95 toddthetoad95 is offline
AKA: Todd
FRC #0649 (MSET)
Team Role: Photography
toddthetoad95 is an unknown quantity at this point
Modular connector between motor and Victor?
We are planning on having our entire arm manipulator being able to be detached from the the drive train base. From our current design, we would need to be able to detach several cables connecting the motors on the arm section to the Victors on the drive train base. We are planning to use COTS modular connectors to accomplish a quick disconnect method.
Is this legal?
According to <R03>, it says COTS electronics are prohibited if they "Directly affect any output devices on the ROBOT. Examples of items that are considered affecting the output devices on the ROBOT include those that directly power a motor, supply a PWM signal directly to a speed controller or supply a control signal directly to a relay module."
We think this should be legal because it's only a quick disconnect, and we are not directly interfering with signals or the such.
Thanks
Unread 24-01-2011, 20:18
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: Modular connector between motor and Victor?
We used Anderson connections two years ago to make it easy to remove the motor from our seventh wheel drive. You can always ask the Q&A question to be 100% sure.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 24-01-2011, 20:21
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I think this is simplified by analyzing the key words that would affect what the answer is. Ironically, that word is "affect" here.
I would venture to say that the GDC means "affect" in the context of "changes in any way". I say that because many teams use quick connects between the motors and speed controllers. My team has used these under the same wording of rules in previous years with only 1 question about their usage from an inspector. That question what "what is their power rating in Amps?".
Unread 26-01-2011, 08:10
Todd,
This is your answer...
<R40> All active PD Board branch circuits shall be wired with appropriately sized wire:
The branch circuit may include intermediate elements such as COTS connectors, splices, COTS flexible/rolling/sliding contacts, and COTS slip rings, as long as the entire electrical pathway is via appropriately gauged conductors.
We have used Anderson 45 amp connectors for many years and connect most motors using them. In addition they can be snapped together in a variety of ways to form multipin connectors for detachable assemblies. Should you choose to use these, be aware that they can be assembled in a manner that allows only one orientation to connection.
Unread 26-01-2011, 08:49
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Seconded, third-ed, fourthed, , , N-thed about the Anderson powerpoles. They also come in various colors to aid the correct assembly of wiring. I'm surprised that someone hasn't approached Anderson for a small sample sack to include in the KoP! Maybe next year?
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 26-01-2011, 09:31
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
R-40 says it all. I think R-03 was referring to anything supplying power to motors directly cannot be COTS, but you can put connectors between the motor and the motor controller because the controller, well, controls it. The wires from the motor controller to the motor don't "directly power the motor" as R-03 says, they power the motor after the motor controller.
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
Unread 26-01-2011, 09:33
Daniel,
R03 refers to electronics and custom circuits.
Unread 26-01-2011, 09:48
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Anderson modular connectors
housings
McMaster P/N
8026K52 Housing for 15, 30, & 45 Amp, Black Modular Connector, Packs of 5 (Same as 8026K5)
8026K51 Housing for 15, 30 and 45 Amp, Red Modular Connector, Packs of 5 (Same as 8026K5)
connector pins for housings above, the different pins accomodate different wire sizes, all pins fit in the above housings
McMaster P/N
8026K95 Modular Connector Contact, 45 Amps @ 600 VAC/VDC, Packs of 5
8026K91 Modular Connector Contact, 30 Amps @ 600 VAC/VDC, Packs of 5
8026K96 Modular Connector Contact, 15 Amps @ 600 VAC/VDC, Packs of 5
Ed Barker
Unread 26-01-2011, 10:00
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Power Pole connectors rock.
http://www.westmountainradio.com
Unread 26-01-2011, 10:47
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
I'll chime in here and add that we love the PowerPole's as well... used them for the first time last year, and we'll be using them again this year. Having a proper crimp tool for them is also highly recommended - it makes everything a lot easier:
http://www.westmountainradio.com/pro...ts_id=PWRcrimp
Unread 26-01-2011, 11:19
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
housings
McMaster P/N
McMaster P/N
Thanks for posting these part numbers. Do you know if these are genuine Anderson brand? I know on the 50A ones from McMaster, they are a different brand.
Unread 26-01-2011, 11:27
As does West Mountain Radio for sales and service. I've used them for years and have been super happy with them.
Unread 26-01-2011, 11:38
Sandy,
They are not exactly the same but do mate with Andersons. We used them for a while but now buy the official connectors.
