Go to Post This thread is just as lethal as any design your own game thread. - Schnabel [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.50 average. Display Modes
  #136   Spotlight this post!
Unread 26-01-2011, 12:07
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Re: Minibot climb rate
Originally Posted by JB987 View Post
Don't believe everything you see...all may not be as it seems. See the other related thread highlighting 1625's minibot climb. Do you clearly see the 1.5 lb. battery on the skyrocketing minibot? Do you vaguely see it?
You are correct... could be an "illegal" minibot.... I STILL envy that speed...Or maybe it's the Mythbuster-ish destruction that occurs when it slams into the top! COOL!
Steve
  #137   Spotlight this post!
Unread 26-01-2011, 12:59
Tobot Tobot is offline
AKA: Toby
FRC #1827 (Robojackets)
Tobot is just really niceTobot is just really niceTobot is just really niceTobot is just really nice
Originally Posted by Chris is me View Post
Direct driving two 4" wheels (not sure on one for each wheel or both mechanically linked to a lower "gearbox")
It is my assumption that "direct drive" in this thread refers to driving a wheel directly from the motor shaft. In other words, without the Tetrix gearbox attached. Is this correct?
My team is considering the idea of doing away with the tetrix gearbox. But I don't like the looks of that 2.5 mm motor shaft.
  #138   Spotlight this post!
Unread 26-01-2011, 13:13
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
I believe when everyone says direct drive, they mean with the tetrix gearbox, considering you cannot alter the motors (which I assume means the gearbox connected also).
If I am wrong, please smite me. Thats what I meant whenever I said directly driven.
  #139   Spotlight this post!
Unread 26-01-2011, 13:17
Chris27's Avatar
Chris27 Chris27 is offline
AKA: Chris Freeman
FRC #1625 (Winnovation)
Chris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant future
*smite*
http://forums.usfirst.org/showthread.php?t=16187
ye of little faith...
  #140   Spotlight this post!
Unread 26-01-2011, 13:51
Chris is me's Avatar
AKA: Pinecone
I meant a direct drive off the stock gearmotor, not motor sans gearbox.
The latter could be done but for my team at least it's beyond our capabilities.
  #141   Spotlight this post!
Unread 26-01-2011, 15:08
AKA: Toby
I propose that from here on in we specify what we mean when we say "direct drive."
My team is in the same boat regarding technical ability to use the motor shaft. On the other hand, I cracked open the tetrix gear box last night. With some moderate machining capability, one could signicantly modify the ratio of the gearbox. I took a couple of photos that I will try to put up this evening (CST).
I would love to use the internal gearbox alone for several reasons. Not the least of which is that two of our wheels and a driven tetrix gear came loose on our first climb test.
  #142   Spotlight this post!
Unread 27-01-2011, 22:18
AKA: Toby
Here's an internal view of the Tetrix gearbox:
It looks possible to mate the brass helical gear to the 40T gear on the output shaft, with a little bit of machining. Sorry this post is a day late.
  #143   Spotlight this post!
Unread 27-01-2011, 22:30
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Originally Posted by Chris27 View Post
Or a just a case of skepticism with the treatment being a clearer video with close up?
  #144   Spotlight this post!
Unread 28-01-2011, 09:11
Generator of Entropy
FRC #2973 (The Mad Rockers)
Thanks for the pic. How many teeth on the gear on the input shaft that mates to the 26 tooth gear?
  #145   Spotlight this post!
Unread 28-01-2011, 09:31
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Math would say 10. (40/10)*(25/15)*(30/10)*(26/10)=52:1
  #146   Spotlight this post!
Unread 28-01-2011, 09:43
AKA: Toby
10 teeth on the helical gear on the motor shaft. This makes the ratio input 52:1 output for the gearbox and motor as assembled. Mating the 10 tooth element of the 26:10 brass gear to the 40 tooth output shaft gear would yield
input 10.4:1 output for the same assembly.
  #147   Spotlight this post!
Unread 28-01-2011, 09:44
Jared Russell's Avatar
Taking a year (mostly) off
(Picture Omitted)
That is exactly what we did (using only an inexpensive mill and lathe and a dremel), and it works great.
  #148   Spotlight this post!
Unread 28-01-2011, 10:26
AKA: Pinecone
Do the gains in efficiency offset the lower torque output of the motor, or is this an "experts only" mod for teams that make custom 2" wheels?
How dramatic is the speed gain? 1625-dramatic?
  #149   Spotlight this post!
Unread 28-01-2011, 12:26
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire (on sabbatical))
The dyno data showed a ~60% increase in output power. That makes it 1625 fast. You would definitely have to do some custom gearing and probably custom wheels (custom wheels will remove the necessity for some of the gear ratio). The big thing is to get the gear/wheel combo right so your reflected torque to the motor is ~50% of stall.
  #150   Spotlight this post!
Unread 28-01-2011, 13:20
Here's a tip, whether or not you chose to modify the gearbox. We found in years past that cleaning the stock grease from our NBD gearboxes and using light lithium grease had a noticeable improvement in output (efficiency). It looks like this gearbox is pretty clean - don't know if it was that way when you opened it, but even if it was well lubed it might be a good idea to clean it out and put in lithium grease. (which per update 5 is an allowable material).
