Go to Post Hmmm... I'm pretty sure that twig isn't legal, since the tree it came from started fabrication before kickoff.... - lukevanoort [more]
  #31   Spotlight this post!
Unread 10-01-2011, 09:22
Dancin103 Dancin103 is offline
The Crazy Blonde
AKA: Cassie
FRC #0103 (Cybersonics)
Dancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond repute
Send a message via AIM to Dancin103
Re: Logomotion Score Calculator
Originally Posted by Hallry View Post
It always says that it is unable to open the file...maybe because our macs are supplied by the school and certain applications are blocked?
Edit 1: This is the notification I get when I try to get it:
Attachment 9618
Unfortunately, the application Console is 'not allowed'...
I would say that there is an internal block of what you can view and use and what you can't. You probably aren't allowed to add any programs that aren't "approved" of but I'm sure someone on your team knows a way around it. If not let me know and I will see what I can do.
Cassie
Cybersonics Technology Team 103
2003 Championship Chairman's Award Winners
NEED CHAIRMAN'S HELP?? Subscribe to our YouTube Channel, we answer your questions daily!
  #32   Spotlight this post!
Unread 10-01-2011, 09:43
bassoondude bassoondude is offline
1293 Awards and Rules Captain
AKA: Miller
FRC #1293 (D5 Robotics)
bassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to behold
Originally Posted by tomy View Post
cant you get put two tubes on one peg?
you can, but unless one is an ubertube, only the outer tube works by <G63>
2011 Palmetto Regional: Semi-Finalists
2010 Palmetto Regional: Semi-Finalists
2009 Palmetto Regional: Quaterfinalists
  #33   Spotlight this post!
Unread 10-01-2011, 09:52
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Cassie
I'm pretty sure someone on my team will be able to get it to work, and I'll keep you posted on his success.
  #34   Spotlight this post!
Unread 10-01-2011, 23:48
ahollenbach ahollenbach is offline
AKA: Andrew
ahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to all
i found one flaw!
when you put one of each of the tube in the right order you get 18 points
then when you place an uber tube on it it says 18*2=30
and also cant you get put two tubes on one peg?
sorry to point out flaws i hate doing!!!
This is actually a common misconception I've seen.
1. The ubertube is a peg multiplier; it will not multiply the row by 2.
2. You can put more than one on per peg, but only the outermost counts.
3. The score is calculated as follows: (3+3+3)*2 for logo, =18, and can be written 6+6+6. Then lets say you have an ubertube on the first one. This makes it 6*2+6+6, and then add a 6 on top of that for your autonomous placement score. Five 6's make 30.
P.S. If you don't want to point out flaws so much...read the manual so you don't have to
  #35   Spotlight this post!
Unread 10-01-2011, 23:51
AKA: Andrew
Originally Posted by Roger View Post
The official scoring screens at Kickoff. Touch screen panels, each peg changes shape each tap. Doesn't show a score however. Could keep a body busy during a match!
Yeah, more pretty! Like Edison, I've discovered that a program is 1% basic stuff and 99% pretty stuff.
- Contrasting background.
- Autonomous mode (yellow tubes).
Sweet pic
I agree with the contrasting background (with the brightness of certain screens, it is impossible to see a white circle on the background), and this has been rectified. Unfortunately, I forgot to bring home a copy from school
  #36   Spotlight this post!
Unread 26-01-2011, 13:06
GeorgeTheEng's Avatar
GeorgeTheEng GeorgeTheEng is offline
Former Lord of the Vex
AKA: George Marchant
FRC #0087 (Red Devils)
GeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud of
Send a message via AIM to GeorgeTheEng
If anyone in interested I put together scoring calculator for the iPhone that is available in the app store. The only has two bugs (that I am aware of).
1) It does not address penalties. Thos may get added in an update if I have time
2) It allows 3 ubertubes per scoring grid rather then three total
http://itunes.apple.com/us/app/frc-s...415226379?mt=8
There is also a scoring calculator available for FTC
George Marchant - Lockheed Martin Engineer & General Nut Case
FIRST Credentials: Team 87 Mentor | Former Director FIRST Vex Challenge
NJ FIRST Planning Committee Member & NJ FVC Committee Member
Philadelphia Alliance Regional Corporate Advisory Board Member |
FRC and FTC volunteer at too many places to list (NJ, VA, DE, PA, NY, Championship)|
"Hi my name is George and I'm a FIRST-aholic. I've been a FIRST-aholic since 2000..."
  #37   Spotlight this post!
Unread 26-01-2011, 13:09
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Awesome! Thanks!
I do not have an iPhone, but I will be sure to tell my friends.
  #38   Spotlight this post!
Unread 29-01-2011, 16:11
cd5696's Avatar
cd5696 cd5696 is offline
&amp;lt;insert something creative here&amp;gt;
FRC #2451 (Pwnage)
cd5696 is an unknown quantity at this point
oh wait does the uber tube double the whole thing or just the tube its connected to?
only the peg it's on.
  #39   Spotlight this post!
Unread 31-01-2011, 16:48
soxfan269's Avatar
soxfan269 soxfan269 is offline
FIRST Team 3620 Team Member
AKA: Daniel Michaels
FRC #3620 (Average Joes)
soxfan269 is an unknown quantity at this point
Originally Posted by Cyberphil View Post
Hey everyone,
After diligently working for a few hours, our programmer came up with a score calculator for the game. I have posted the program and the source code (Java) so feel free to mess with it as you please. You will need Java to run this program. It is covered under the WTFPL Licence.
Hope this helps!
Edit:
Directions-
Left click- Change Shape
Right Click- Add Ubertube (Just remember that you can only have a maximum of 3)
You can add the race score by yourself, or add it to the program.
Thanks for the program, I wish it would've had uber tubes. But good job anyway.
  #40   Spotlight this post!
Unread 01-02-2011, 17:05
Cyberphil's Avatar
That Guy
AKA: Phil
It does have Ubertubes. Right click on the boxes and the Ubertubes will be placed.
