Go to Post I'm absolutely certain that kids prefer scoring points to not scoring points - AdamHeard [more]
Unread 26-01-2011, 03:14
shai's Avatar
shai shai is offline
Team Captain
FRC #3083 (Artemis)
shai has a spectacular aura aboutshai has a spectacular aura aboutshai has a spectacular aura about
D-Link power feed - converter
Hello all,
A few days ago we tried to configure and test our D-link AP, but when then we saw that the AP power connection is 5V. There is only one 5V output on the PDB and it is used for the Axis camera, so how should we connect it?
The power distribution diagram shows that we should use a 12V - 5V converter, Are there any rules about this converter or can we use any one we buy?
Thanks,
Shai, team #3038
Unread 26-01-2011, 03:33
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Team Role: Electrical
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
Re: D-Link power feed - converter
There's one in the kit. Looks kinda like a heat sink with 4 wires coming off of it. No need to go shopping.
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
Unread 26-01-2011, 07:59
Shai,
The robot rules state you must use the power convertor in the KOP.
<R38> All electric power utilized by the ROBOT shall be distributed from the load terminals of the PD Board. Circuits may not bypass the PD Board to connect directly to the 120-amp loop.
B. The radio power feed must be connected via the 5V converter (model # TBJ12DK025Z) to the marked 12 Vdc supply terminals located at the end of the PD Board (i.e. the terminals located between the indicator LEDs, and not the main WAGO connectors along the sides of the PD Board). No other electrical load can be connected to these terminals (please see the 2011 Robot Power Distribution Diagram posted online at www.usfirst.org/frc/kitofparts for wiring information).
Unread 26-01-2011, 09:01
Here's a photo of the converter that came in the KOP.
It's inside a small white box.
http://www.chiefdelphi.com/forums/at...2&d=1294671172
If you have to order one it'll come after the Chinese New Year on a slow boat from China...
Unread 26-01-2011, 12:00
shai's Avatar
Team Captain
FRC #3083 (Artemis)
Thanks, I'm pretty sure we got it this part in our elctronics box.
Unread 26-01-2011, 12:38
DtD's Avatar
DtD DtD is offline
I hope the watchdog starves!
AKA: Pathogen David
FRC #2410 (The Metal Mustangs (Merged from 2334, Hazmat Robotics))
DtD will become famous soon enoughDtD will become famous soon enough
Be careful when you hook it up. When I did it, I saw the yellow wire and though "Ah, 12 Volts, like on a computer PSU" and red for 5 V (Also typical color for the 5 V lines in a computer PSU)
Result: 44 volts through the DAP-1522. NOT FUN.
Also, the switching voltage regulator inside, which I suspect blew, had a maximum rating of 42 volts.
If you do blow it, Amazon has a nice $15 rebate + sale so they are only $57. We bought two.
Unread 26-01-2011, 13:38
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
For reference purposes, can you explain the wiring (regarding which color goes where and is hooked to what)? I suspect we are going to have to cut up last year's power cables and splice but it would be nice to know for sure; we're (and by that I mean me) setting up the radio for power today.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 26-01-2011, 13:46
Referring to the back of the converter...
12v side:
  • red(+) -> white wago connector -> PD reserved wireless connection
  • black (-) -> same wago
5v side:
  • yellow(+) -> white stripped wire leading to barrel connector
  • black (-) -> solid black wire to barrel connector
The barrel connector and wire can be cut off the wall wart that came with the D-Link, or use last year's (if it's the right size), or purchase one.
TEST with a multi-meter before connecting the barrel connector to the D-LINK.
Red lead inside the barrel, black lead on the outer casing.
Center MUST be positive and Must read +5v.
Last edited by Mark McLeod : 26-01-2011 at 20:00. Reason: Last year's barrel connector is not the same size, thanks Al
Unread 26-01-2011, 13:49
Zuelu562's Avatar
AKA: Jake Janssens
Thanks Mark. Much Appreciated.
Team Resume
Volunteer Resume:
The coaxial power connector from last year's radio is a different size than the Dlink.
Unread 26-01-2011, 19:57
Originally Posted by Mark McLeod View Post
The barrel connector and wire can be cut off the wall wart that came with the D-Link,...
We cut that wire and inserted a set of PowerPole connectors so we could use the transformer again if/when desired. We installed a matching pair of connectors on the output of the power converter. The converter's input wires go directly to a Wago plug.
Unread 28-01-2011, 08:57
P.S.
Talked with Al. It seems his old barrel connector is not the same as mine, so check your own to see if they are reusable this year.
Not all old Linksys connectors are the same as the D-Link.
The outside barrel must be the correct fit, but also the inside center must not be loose (Al's issue) on the D-Link pin. Some barrel connectors have a larger center hole than others. The ones we got with our Linksys in 2009/2010 have, in addition to the center hole, a pair of spring contacts.
Here's a comparison shot of one of the Linksys wall-warts that matches the D-Link.
Unread 28-01-2011, 09:14
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
I did the same thing but checked voltage before plugging in. What I want to know is : what kind of circuit is cool enought to step up or down a dc voltage based on which way you plug it in???????
Phil Malone
http://www.GEARSinc.org
