Go to Post Gotta love the use of universal technical terms, along with whatchamacallit, doodlespiel, whosiwhatsit... ;) - PaW [more]
Unread 24-01-2011, 11:14
Unglued Unglued is offline
AKA: Andrea Valenzuela
None #0865 (Warp7)
Team Role: Animator
Unglued is on a distinguished road
Send a message via AIM to Unglued Send a message via MSN to Unglued
Using Encoders with Labview and Mecanum wheels
Hello
we have used the encoders on our mecanum wheel bot and after receiving input, it can be seen that the four wheels don't rotate at the same speed. How how do we get all the wheels moving at the same speed using labview?
Thanks for your help in this matter and have a great day.
Unread 24-01-2011, 11:47
Re: Using Encoders with Labview and Mecanum wheels
Step one: Make sure you don't have any mechanical issues. Any extra friction on the motor/gearbox/axle/wheel system will mess you up, and unbalanced weight distribution can also lead to difficulties in controlling things.
Step two: Make sure your code knows what kind of speed controllers you are using. Victors and Jaguars have somewhat different default response to the PWM signal. The WPI Library motor control functions know about this and take it into account.
Step three: If you are still having problems, ask again (and mention closed-loop speed control).
Unread 26-01-2011, 08:15
None #0865 (Warp7)
Team Role: Animator
1. everything is great mechanically, right now it's just a frame wheels and electronics,
2.we re using jaguars, it's in the programming.
what would the term be for what i am looking for? i want all wheels operating at the same speed, prefferibly without close looped anything, becasue of the rule change this year
we are getting readings from the encoders how do we tell the jags to stay at a constant speed?
Unread 26-01-2011, 16:24
BenGrapevine's Avatar
BenGrapevine BenGrapevine is offline
Head Programmer
AKA: Tony Simmering
FRC #2549 (Millerbots)
BenGrapevine is an unknown quantity at this point
Originally Posted by Unglued View Post
Hello
Jaguars respond slower than victors, so it would help to know which are on your bot.
Millerbots Team 2549
orange and blue
Unread 26-01-2011, 16:56
None #0865 (Warp7)
Team Role: Animator
once again, we are using jaguars.
