Go to Post You're never too cool for a giant conga line around an arena. - Michelle 236 [more]
Unread 25-01-2011, 17:44
Eagleeyedan's Avatar
Eagleeyedan Eagleeyedan is offline
C.O.R.E.; We build on each other
AKA: Daniel C.
FRC #2062 (C.O.R.E. 2062)
Eagleeyedan is a jewel in the roughEagleeyedan is a jewel in the roughEagleeyedan is a jewel in the roughEagleeyedan is a jewel in the rough
Question Resizing the iiko?
How does one re-size the iiko model? When I select all his parts, it re-sizes his eyes and teeth at a faster rate than his body. If I only select his body, it makes the dummy objects not re-size with him and then they don't control him anymore. HELP!
Former Driver and Safety Captain of team C.O.R.E. 2062 (Community of Robotic Engineers)
2015: Wisconsin Regional- Champions, Industrial Safety Award
Midwest Regional - Champions, Industrial Safety Award, Industrial Controls Award
2014: Midwest Regional - Judges Award
2013: Lake Superior Regional - Champions
2012: World Championship - Industrial Safety Award, World Finalist for the Autodesk Award
2011: Wisconsin Regional - Website Award 10,000 Lakes Regional - Innovation in Control, Safety Award
2010: World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
10,000 Lakes Regional - Regional Champs, Entrepreneurship Award
Wisconsin Regional - Entrepreneurship Award, Industrial Safety Award
2009: WI Regional- Quality Award, Industrial Safety Award
10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008: World Championship - Industrial Safety Award,
Wisconsin Regional - Champions, Industrial Safety Award
Unread 26-01-2011, 10:48
3DElizabeth's Avatar
3DElizabeth 3DElizabeth is offline
Animation Mentor
AKA: Elizabeth Barndollar
FRC #0342 (The Burning Magnetos)
3DElizabeth is on a distinguished road
Re: Resizing the iiko?
Tings may have changed but when I was in school you could not resize a rigged character because it will mess up the rigging and you will get insane results.
For just resizing all of the pieces though, select them all, group them, and then resize them, ungroup when you are done.
Hope this helps. Good luck.
Unread 26-01-2011, 13:17
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Just like what Elizabeth said, make all of your other models fit with the size of the Iiko.
And when you do scale the rest of the scene up, select everything, group it, resize it, and ungroup it(If needed).
Unread 26-01-2011, 19:26
AKA: Daniel C.
But you can't group the iiko model.
Unread 26-01-2011, 19:27
AKA: Daniel C.
What I need to do is make some iiko normal size and some bigger for a classroom scene. Some need to be students and some adults.
Unread 26-01-2011, 21:55
PHREDETTE PHREDETTE is offline
FRC #0847
PHREDETTE is an unknown quantity at this point
Yes, I need both children and adults as well.
Unread 27-01-2011, 13:38
Nerd_Skywalker's Avatar
Nerd_Skywalker Nerd_Skywalker is offline
Walker of Skies
FRC #1111
Team Role: Animator
Nerd_Skywalker is an unknown quantity at this point
You could use some camera trickery
i.e. Have the camera close up when you are showing the adults and further back when showing the kids. Just don't have them both in the same shot.
Re-dun-dant adj. 1. See redundant
Unread 28-01-2011, 16:34
AKA: Daniel C.
Too late for that. They are in a class. It's okay. It looks fine with them the same size. I just animated them all so they are all moving now so you don't really notice. The only thing I don't like about the scene is that the shadows go in 2 directions because I created a dalight system outside but it isn't bright enough to light up the whole room. It only lights up right in front of the windows. I had to add a second,dimmer light on the oppiste side which creates confilicting shadows. Otherwise, the scene looks fine.
Unread 29-01-2011, 07:56
Walker of Skies
FRC #1111
Team Role: Animator
I don't really understand lights...all of my videos have bizzare shadows
Unread 29-01-2011, 21:25
AKA: Daniel C.
Have you set up your units? It really helps with lighting.
Unread 31-01-2011, 19:54
rastermon rastermon is offline
FRC #0847
rastermon is an unknown quantity at this point
The only thing I don't like about the scene is that the shadows go in 2 directions because I created a daylight system outside but it isn't bright enough to light up the whole room. It only lights up right in front of the windows. I had to add a second,dimmer light on the oppiste side which creates confilicting shadows. Otherwise, the scene looks fine.
If you have lots of processing power and time, try turning on Global Illumination - Final Gather. You need to render with Mental Ray - not the default scanline renderer. That will calculate bounced light around the room, and you may not need the second fill light. But it takes much longer.
Unread 01-02-2011, 14:03
AKA: Daniel C.
I already renderd it out. I am also already using te MR renderer. It's the default one for 3DS MAX design 2011.
