Go to Post Stand up and cheer for yourselves and others. That is FIRST, don't change it. - Steve W [more]
Unread 26-01-2011, 17:05
seannoseworthy's Avatar
seannoseworthy seannoseworthy is offline
FRC #2200 (MMRambotics)
seannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to behold
Send a message via MSN to seannoseworthy
pic: So, Andy Mark was sold out!
Unread 26-01-2011, 17:06
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pic: So, Andy Mark was sold out!
I'd like to know how you're holding the sprocket, or are you not cutting all the way through, or has the hold-down been removed already in this photo?
Unread 26-01-2011, 19:58
Brandtlamonte Brandtlamonte is offline
FRC #2080
Brandtlamonte is an unknown quantity at this point
Since you have 3 mind loaning my team one? =p
Unread 26-01-2011, 23:26
The stock is held down with the dogs you can see, once the tooth profile is cut there is about 10-20 thou of material left and at that point i removed the sprocket from the stock material and began filing.
Unread 26-01-2011, 23:38
If you did the whole operation on a fixture plate, you could probably mill the bore, then drill and tap a hole in the fixture plate, then put a bolt with a fender washer in it, then cut through the entire outer profile. Just curious, what did you use in CAD for the tooth profile?
Unread 26-01-2011, 23:53
Big Ideas Big Ideas is offline
AKA: Stephen des Jardins
FRC #2102 (Team Paradox)
Big Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant future
For flat pieces it's possible to hold the stock with double sided tape (thin like carpet tape) on a sacrificial subplate like MDF, HDF, or MDF with melemene. Or drill a few tooling holes and screw the stock down the the subplate. This way you can make your final thru cut and not have to file all of those perfectly machined teeth.
Unread 27-01-2011, 00:20
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Double-sided tape on MDF won't work if you intend to use coolant. I've also had issues with parts shifting slightly on non-coolant milling (engraving acrylic) when relying only on double-sided tape to hold the parts in place.
Using a fixture plate (as sandrag already mentioned) is the best method. Since all AM sprockets have the same "standard" Ø1.875" six hole pattern, just make a permanent fixture plate if you intend to mill a lot of sprockets.
I've milled 25p sprockets from the CAD models available on McMaster and/or SDP-SI. I've been meaning to create an equation-driven SolidWorks model where you can just edit the number of teeth in the equation and hit Rebuild to make any size sprocket you want (I did that with gears a few years ago), but downloading existing part models is easier...
Art Dutra IV
世上无难事,只怕有心人.
Unread 27-01-2011, 10:53
The fixture plate we used was already made and ready to go and because we are only making 2 -4 we did not bother drilling and tapping. The tooth profile was created using the Roller Chain Generator in Inventor. The .ipt file was then imported to mastercam X.
Unread 27-01-2011, 11:08
Brandon Holley's Avatar
Following the old saying of "Work smarter, not harder". Totally agree, CAD files are so easy to find on the net (Mcmaster + SDPSI) that it makes it completely painless.
Also ditto the fixture plate, it's how we make almost all of our flat plates on CNCs.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 27-01-2011, 11:30
Big Kid's Avatar
Big Kid Big Kid is offline
The Coach
AKA: Nick Acosta
FRC #0816 (WesTech Anomaly)
Big Kid is a jewel in the roughBig Kid is a jewel in the roughBig Kid is a jewel in the rough
Send a message via AIM to Big Kid
I was trying to do this on our team's 3 Axis CNC Mill, and I only managed to get one done right. The other attempts all seemed to have distorted pitch diameters. Any suggestions on how come this kept happening and any tips on how to fix it?
I used CAD files from McMaster, and I had the stock mounted to a mounting plate we made for the sprockets.
Team 816
Student (2007-2011)
Mentor/Drive Coach (2013-)
Team 2495
Mentor (2016-)
Graduate Mech. Engineer at Lehigh University
Unread 27-01-2011, 11:54
James Tonthat James Tonthat is offline
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Just an FYI, one of the forum sponsors, Innovation First sells 35 plate sprockets.
http://www.vexrobotics.com/products/...sprockets.html
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
