Go to Post If you have a robot you don't need any more, use it for demos, or let a rookie team borrow it to learn wiring, programming, and demo around their school. - Barry Bonzack [more]
Unread 26-01-2011, 20:19
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Re: Classmate not connecting wirelessly
oh... that would not make a difference
and you said it wasn't picking up any wireless you say?
Unread 26-01-2011, 20:20
Robobuff1.0's Avatar
Robobuff1.0 Robobuff1.0 is offline
FRC #1633
Robobuff1.0 is an unknown quantity at this point
correct, but for some reason it auto connects to one of the ASU networks nearby.
Unread 26-01-2011, 20:22
when you go to set up your change your ip address look at the other tabs there should be one that at the top is says "Use window to control your wireless"
make sure that is checked
Unread 26-01-2011, 21:10
Until you said that, it sounded like the wireless network adapter on your Classmate might be broken or misconfigured. Now it just sounds like you're not paying attention to what you're saying.
Let's start at the beginning. If you've reimaged your Classmate and applied the Driver Station update, you should be able to log on as the Driver and set your team number. That will set the IP address appropriately, and if the D-Link is properly configured and powered up, you should be able to connect to it without extra effort.
Did you reimage your Classmate and apply the Driver Station update?
Unread 26-01-2011, 22:47
FRC #1633
I beleive that i did reimage and do the DS update, because i had to reenter our teams number.
Unread 26-01-2011, 22:52
so for sure your wireless is working right
and can you connect to the internet?
Unread 27-01-2011, 17:40
FRC #1633
sorry for the delayed reply. but no the classmate cannot connect to the internet.
Unread 28-01-2011, 18:02
FRC #1633
are there anymore ideas of things that might be wrong?
Unread 28-01-2011, 19:06
If it's still not working and you have tried reimaging it than put another post
Unread 29-01-2011, 10:51
FRC #1633
ok. so i was just looking at the updates that i had downloaded and the one that had downloaded and done on the classmate was the Driver station update http://joule.ni.com/nidu/cds/view/p/id/2263
so i am not sure if i have actually re-imaged the classmate.
Unread 29-01-2011, 16:29
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
The OP states
The classmate is also configured to 10.16.33.5 (in local area connection though not sure if i need to change that to wireless connection).
Yes, you need to make sure the wireless connection is set to a proper IP address (either manually or by the Driver Station software) and enabled.
Right click on the wireless adapter, properties, IPV4, properties. Click on "Use this IP Address" and enter something like 10.16.33.7. Set the subnet mask to 255.0.0.0 click OK to get out.
We've had luck by right clicking the wireless adapter and selecting "Connect/Disconnet network". Connect to the DLINK, it should have an ID of 1633 if you followed the instructions correctly. It might prompt for a WPA key, in that case enter the WPA key you entered during the DLINK setup, if you used the default setting in the instructions it would be 1633WPAKEY.
Hope that helps
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 30-01-2011, 11:59
If you didn't boot from the USB flash drive that came in the Kit of Parts, and if you didn't wait through about twenty minutes of reformatting and copying of files, and if you didn't get asked to create a new user name, and if you didn't find the Classmate nagging you about activating your copy of Windows 7...
...you haven't actually re-imaged the Classmate.
Go to the Kit of Parts web page and follow the instructions in How to Set Up Your 2011 Driver Station (updated 1/11/11). If you intend to install LabVIEW or other programming environments on the Classmate, make sure you first read and follow the Classmate Drive Space Recovery Procedure (NEW 1/11/11).
Unread 31-01-2011, 17:41
FRC #1633
will having any extra files on the flash drive affect it in any way?
Unread 31-01-2011, 18:25
No, but you really shouldn't use it that way.
It should be put away for safekeeping as your restore in case something happens and you need to recover the Classmate.
