Go to Post Nah, I never crash or break anything... - Elgin Clock [more]
Unread 26-01-2011, 19:55
inou8it inou8it is offline
Captain/Founder/Student
inou8it has a spectacular aura aboutinou8it has a spectacular aura about
Rookie Team Help- Robot Won't Move
Hello,
We just finished doing our wiring for the basic robot. We connected 2 jaguars to the 40 amp maxload and the other side to our two 12V DC motors running the chains connected to our wheels. When we put our code in and try to make it move using our joysticks, nothing happens. We are using the DefaultRobot java code. Any ideas why it won't move? Thanks,
Alex
Unread 26-01-2011, 20:00
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Re: Rookie Team Help- Robot Won't Move
clear photos of the robot, electronics, all connections and the controls would help. Your issue could be hardware, electronics/connections, software, or some combination thereof.
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 26-01-2011, 20:16
http://dl.dropbox.com/u/1281656/down...0126111911.jpg
Unread 26-01-2011, 20:27
Our jaguars are also flashing yellows lights
Unread 26-01-2011, 20:28
http://dl.dropbox.com/u/1281656/down...0126111911.jpg is a picture of our robot
Unread 26-01-2011, 20:35
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Check to make sure the PWM wires are not plugged in backwards ie: the plug flipped 180deg. in the slot.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 26-01-2011, 20:37
The PWM wires are plugged in correctly
Unread 26-01-2011, 20:42
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Did you enable the control board when you pushed the joysticks forward?
Unread 26-01-2011, 20:43
Howe do we do that?
Unread 26-01-2011, 20:45
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Try using the Digital I/O module in slot 4 of the cRIO. I believe the default code uses that one.
Unread 26-01-2011, 20:47
The digital module connecting the Digital sidecar is in the wrong slot.
It should be in slot 4.
And you can get rid of the extra Digital module.
The Analog module in slot 6 should come out. It, too, is in the wrong place, but you don't need it anyway.
All you need for now is an Analog Module in slot 1 (you do have it there), and a digital module in slot 4.
Unread 26-01-2011, 20:51
We are receiving the message "waiting to connect to OTA" in netbeans. It is attempting to connect through port 8001, and we assume this is correct. We can connect to it via FTP so we can assert that it is connected properly. The software has been updated on both the crio and the laptop. Why are we receiving this error message? We have successfully uploaded code at one point but this problem seems intermittent.
Unread 26-01-2011, 21:28
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
Just as a side note, i'd think about moving that battery to the center for better weight distribution. Since you're using tank drive it's not a big deal, but it's usually something you want to keep in mind.
Unread 26-01-2011, 21:43
awesomegeek166's Avatar
awesomegeek166 awesomegeek166 is offline
AKA: Ashley
FRC #2130 (Alpha Plus)
Team Role: Marketing
awesomegeek166 is an unknown quantity at this point
Did you push the ON button?
Unread 27-01-2011, 13:31
simon911011 simon911011 is offline
FRC #3734
simon911011 is an unknown quantity at this point
What do you mean by the ON button?
