Go to Post A poor robot with good drivers playing on good strategy will whomp a good robot with poor drivers running on poor strategy any day. - henryBsick [more]
Unread 21-01-2011, 16:08
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
How to control the minibot?
Hi,
We finished designing our mini bot but I thought on a problem.
How to get the motors work when we need(when it is on the tower)?
I thought of a touch sensor and NXT block to activate the motor but because we don't have FTC we don't have the motors controller(to get the minibot being controlled we need NXT block, touch sensor, motors, battery and the motors controller). So how can we solve this without this part?
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
Unread 21-01-2011, 16:21
Back after 4 years off
FRC #5279
Re: How to control the minibot?
Originally Posted by yarden.saa View Post
Hi,
You can use a light switch to control the bot without the need for the Controller. Design a mechanism to turn on the light switch when the minibot is in position to climb.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 22-01-2011, 00:46
Jim.D Jim.D is offline
FTC #1983
Jim.D is an unknown quantity at this point
Limit switches and common household light switches are legal items to control the motor if you dont want to use the NXT and motor controller.
Unread 22-01-2011, 01:40
dtengineering's Avatar
AKA: Jason Brett
Is there a rule saying that the mini bot motors cannot be running at the start of the match?
I haven't seen it if there is... but then again, I haven't been keeping up with Q&A as closely as I sometimes do.
Now that I think about it, I'm not even sure where it says they have to stop at the end of the match, so long as you have a way of quickly getting the mini bot back down the pole.
Jason
Unread 22-01-2011, 09:12
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
Jason
I'm not completely positive, but I don't believe there's a rule against that. However, doing so will most likely drain the minibot battery fairly quickly.
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 26-01-2011, 21:05
epic_wts epic_wts is offline
AKA: Will Searight
FRC #1245
Team Role: Electrical
epic_wts is an unknown quantity at this point
Hi, I don't know if this would help, but you could probably use a deploy system, and then use a switch that would trigger once it touches the pole, causing the motors to activate and drive the minibot up the pole.
Unread 27-01-2011, 07:39
Jason,
I think this is the defining rule...
<G19> MINIBOTS must remain completely autonomous and move up the POST solely through electric energy provided after the start of DEPLOYMENT by the permitted, unaltered battery and converted to mechanical energy by the permitted unaltered motors (and associated, appropriate circuitry).
I think that implies that the motors may be running but the minibot may not move vertically until after the start of deployment. Q&A is the place to ask.
However, simple switches can be employed to start, reverse and stop the minibot if one thinks about it.
Unread 28-01-2011, 12:33
kitsume13's Avatar
kitsume13 kitsume13 is offline
The Ginger
FRC #2152 (S*M*A*S*H)
kitsume13 is an unknown quantity at this point
Smile Re: How to control the minibot?
Hey, Dose anyone know if we will be able to use a ladder to get the mini-bot down from the pole
-Rachel
Proud member of First Team 2152 S*M*A*S*H!
2012 South Florida Regional Imagery Award
2013 South Florida Regional Creativity Award
2013 Panther Prowl Finalist (team captain)
2013 Panther Prowl Judges Award
2013 Robocon: Tampa bay Awesome Pit Award
Unread 28-01-2011, 12:44
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
I saw this on another thread. That you can not use a ladder, pole, or another type of tools to get the mini-bot down. And you must get it in a safe manner.
Unread 28-01-2011, 15:16
GaryVoshol's Avatar
Cogito ergo arbitro
GDC says no ladders: http://forums.usfirst.org/showthread...ghlight=ladder
But they haven't said if any other devices are allowed.
EDIT: And now they have said - see Team Update 6.
(since 2004)
Unread 28-01-2011, 18:35
dotbran dotbran is offline
AKA: Brandon Olsen
FRC #3219 (TREAD)
dotbran is on a distinguished road
Are basic electrical components allowed for use on the minibot, like capacitors and photoresistors, to trigger and disable the robot?
Unread 28-01-2011, 22:04
pfreivald's Avatar
AKA: Patrick Freivald
I don't see them on the list of allowable parts... (Indeed, I'd love it if we could use *regular* resistors...)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 29-01-2011, 00:14
AKA: Darrin Munter
Since a relay is like a switch are we allowed to use one in a custom circuit?
Not talking about a Spike relay, but a normal one.
The student that is in charge of the FIRST Q&A didn't show up tonight.
Unread 29-01-2011, 09:41
Guys the list of allowables on the minibot is very specific. Relays are not on the list, components like resistors and photoe sensors are not on the list, except those that are Tetrix parts when used with the NXT that are on the list here...http://www.usfirst.org/uploadedFiles...ix%20Parts.pdf
I have to ask, what would you use the resistor for?
Unread 29-01-2011, 18:03
pfreivald's Avatar
...to make it come back down nice and slowly under drive without a controller.
Team 1551
I write books, too!
