Go to Post Compact gearboxes are a wonderful thing. - Cothron Theiss [more]
Unread 26-01-2011, 22:31
Ethan Spitz Ethan Spitz is offline
President
FRC #3637 (The Daleks)
Ethan Spitz is an unknown quantity at this point
Regulating power to a servo with a relay
Does anyone know if its legal to do this? I wasn't sure if this violates <R48>. It seems fine to <R48>'s statement, but then doesn't seem to look legal in part B. Also <R57> states that servos must be controlled with signals from the digital sidecar, which is still true in our case.
We are using a relay to cut power to a retract servo so we can stop it where ever we want but still using the signal wire on the digital breakout board to control the direction of the servo.
Thanks,
Ethan
www.team3637.com FIRST team 3637's Website: The Daleks
Unread 26-01-2011, 22:34
Cecil's Avatar
Cecil Cecil is online now
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Regulating power to a servo with a relay
I'm not totally sure on this, but wouldn't that blow out the servo anyway?
The power from the Digital Sidecar would give it the 6 volts needed to power it.
If you connected a spike to it using the 12 volt output on the Power Distribution board, I believe it would blow out your motor.
I'm right 90% of the time, so why worry about the other 3%?
Unread 26-01-2011, 22:47
President
We are using a 5 volt regulator with it
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Why would you want to stop it?
The input it gets (PWM - Pulse Width Modulation) controls the angle of the servo, to about +- 85 degrees or so. If you set the angle precisely, it will stop there and hold its position.
If you want it to not hold its position, then turn it off. If you do not feed it a control signal, it will turn itself off. The way to turn it off is to not give it a control signal, either by letting the watchpuppy kill it or by closing the device when you don't want it to move. (since both of those will tell the FPGA to stop outputting a control signal to that device). Neither one is really an answer, but a workaround. I don't really see why you would need to make it stop, since you can't really smoke those little things (from what I've seen at least) and they don't output much power.
Kettering Motorsports
Unread 26-01-2011, 22:49
President
The problem is its a retract servo, so even when you stop giving it signal, it keeps going till its either all the way clockwise or all the way counterclockwise
Unread 26-01-2011, 22:52
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
There is something wrong in your code.
could you please post that code segment and I can take a look at it.
you should be able to stop anywhere in it's range of motion.
-Borna Emami
Team 0x27
Unread 26-01-2011, 22:54
President
No there isn't anything wrong with the code, this is a RETRACT servo. A retract servo is different then a proportional servo. Retract servos only travel from end to end when powered.
Unread 26-01-2011, 22:58
The Lucas's Avatar
CaMOElot, it is a silly place
I think Servo::SetOffline() is intended to stop driving the servo (I've never used it). No need for a workaround
If you don't want this feature, why not use a regular positional servo?
Robot Inspector
Unread 26-01-2011, 23:01
President
Originally Posted by The Lucas View Post
If you dont want this feature, why not use a regular positional servo?
Well we didn't realize that it was a retract when we bought it, and we wanted a real torquey servo (280 oz-in) without breaking 4 watts so this one moves at about a second/60 degrees
Whats the equivalent for labview?
Unread 26-01-2011, 23:05
apalrd's Avatar
More Torque!
VRC #3333
Said function does not exist in Labview.
Unread 26-01-2011, 23:08
President
Haha, ok, thanks.
I did have an idea to make it not move though. I don't know how good it is for the servo though. I was thinking what if I told the servo that when the absolute value of the joystick value is less than .2 to change the direction of the servo every single time that teleop.vi is called. So essentially every 10ms (I think), it would say go left, go right, go left, essentially changing directions so quickly that it wouldn't move.
Unread 26-01-2011, 23:12
apalrd's Avatar
More Torque!
VRC #3333
A servo updates every 20ms (that's how long the FPGA waits between sending PWM pulses) so a 20ms loop should work fine.
Why not just use a proportional servo? Two came in the kit, as part of the camera pan/tilt head (you really only need a tilt head, because you can twist the robot to pan).
Unread 26-01-2011, 23:19
President
Its not for use with the camera, its moving a joint on an arm so we need a really torquey servo.
This servo is 260 oz-in at 1.55seconds/60 degrees
http://www.jrradios.com/Products/Def...ProdID=JRPS791
Do you know of any servos that are:
  • Proportional
  • 260 oz-in or higher
  • and are under 4 Watts of mechanical power
If you do I would appreciate a link to said servo very much.
Thanks!
Ethan
Unread 26-01-2011, 23:24
apalrd's Avatar
More Torque!
VRC #3333
A motor + a potentiometer + code = big servo
A window motor does about 20 watts, is fairly easy to use (if you just bolt your mechanism to the hub), you can use 2 for more power (or even 4 I guess), and it spins at a good speed.
A 775 does 266 watts at peak power, which is 66.5 times as much as the 4w servo. Add another (making that joint powered by 2 775's) and you will have 133 times as much power.
Unread 26-01-2011, 23:26
President
This is true, but we wanted something really really light because its going to be at the height of the top peg and then extended a foot or so outside of the boundaries of the robots chassis.
