Go to Post What can you do? The more time you waste here speculating the less time you have to work on the robot. Go! Build Robots! Now! - Jessica Boucher [more]
Unread 22-01-2011, 11:09
cd5696's Avatar
cd5696 cd5696 is offline
<insert something creative here>
FRC #2451 (Pwnage)
cd5696 is an unknown quantity at this point
Question Can a robot battery be used on the driver station?
My team was wondering if we can bring a 12 volt robot battery to our driver station to power our laptop. we could not find anything in the rules relating to this, so we were wondering if anyone knows if this is legal.
Unread 22-01-2011, 13:11
Re: Can a robot battery be used on the driver station?
If you're planning to use the Classmate, you don't need it. There's a Classmate power supply in every station.
Now, for another laptop, is there a reason that laptop's own batteries won't hold up for long enough to run a match on a normal charge?
I don't see anything against it either. However, I'd ask the Q&A before doing this, just to be on the safe side.
Unread 23-01-2011, 16:17
Warlord Warlord is offline
He-Who-Does-A-Little-Of-Everything
Team Role: Driver
Warlord is a jewel in the roughWarlord is a jewel in the roughWarlord is a jewel in the rough
I had to do this at a competition one year. Someone forgot to turn off the laptop and charge it after they were using it so near the elimination matches the battery was nearly dead. There isn't a whole lot of opportunities to charge during the elimination matches so we took a battery and borrowed another team's power inverter (THIS IS VERY IMPORTANT, YOU NEED A POWER INVERTER).
We didn't get in trouble or anything for using it, so I guess it is fine.
I have NEVER been to a competition where this was true. Is this going to happen just for this year's competitions?
Hell, half the competitions I've been to there wasn't even OUTLETS, so even if we brought our own charger we still couldn't have power.
Unread 23-01-2011, 16:24
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Yes, this is new this year. See the blue box underneath <R75> for confirmation.
There will not be outlets available in the driver's stations per the same blue box.
Unread 23-01-2011, 16:25
I would guess that it'll continue until Classmates aren't the normal driver's station. Look in the blue box following <R75>. There won't be an outlet at the field, but there will be power for Classmates.
Unread 23-01-2011, 16:42
alectronic alectronic is offline
no team (Volunteer)
alectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant future
As confirmed, yes, there will be power for classamates. However, I would not count on being able to bring any other type of power beyond a pre-installed laptop battery. Even if you request through the Q&A, the field staff and FIRST are usually pretty careful about things like power sources around the field, and it would like be ruled no.
Unread 26-01-2011, 22:34
MattG_3165 MattG_3165 is offline
FRC #3165 (Newbots)
MattG_3165 is an unknown quantity at this point
Taking a different approach to this, does anyone have any ideas about the legality of plugging a DC/DC converter into the classmate power supply and using it to power other electronics? I can't find a rule that says that the provided classmate power supply can only be plugged into a classmate...
Unread 26-01-2011, 23:21
Section 2.2.8: "Each setup location also includes a power adaptor cable that may be used to power the Classmate laptops that were provided to teams in 2010 and 2011."
The blue box associated with <R75> says "Please note that 19V DC, 2A power will be provided at the PLAYER STATION for Classmates provided in the 2010 and 2011 KOPs via Classmate power adapters."
The intent is clear. If I were running the field, I wouldn't permit anything but a 2010 or 2011 Classmate to be connected to that power.
